Home > Maintenance & Mods (L405) > Exhaust gas temperature L405 2013 Euro 5 3.0 Diesel
minim
Norway 2013 Range Rover TDV6 Santorini Black
Thougt I'd document this fix of my faulty exhaust gas temperature sensor. I had troubles finding out what the different sensors was as the description they got in gap iid tool doesn't make sense at all. My issue was a intermittent error causing yellow engine light and reduced power. I cut the bad wire, soldered it back up with a fresh wire and used crimp tubing with glue that also makes a weather seal. Wrapped it in alu/butyl for heat protection after. Error is gone.
To identify the sensors I had to heat the engine as all sensors is showing 100C when cold. The faulty sensor was sometimes showing 160 so that one I could figure out by unplugging when it was cold. The others I heaterd the engine so it showed 120-150C and unplugged sensor by sensor. Hope this helps and I got no clue if its the same on the euro6 cars so this is for euro5.
Exhaust gas temperature - Bank 1 - sensor 1 - Pre dpf, right side of the vehicle
Exhaust gas temperature - Bank 1 - sensor 3 - Post-dpf, most rear sensor, connection on gearbox end
Exhaust gas temperature - Bank 2 - sensor 1 - pre catalyst, left side of the vehicle
Exhaust gas temperature - Bank 2 - sensor 2 - post catalyst, left side in the middle of cat/dpf.
The picture is borrowed from this page that describes the exhaust systems on L494 but it's similar on this vehicle so I used it for illutration and help.
https://www.jlridssddmongoose.com/land-rov...fI6hbhSnyQ
My issue was at the end of the gearbox where the sensor had been worn to the metal causing intermittent issues.
Soldered and crimped.
Wrapped in alu foil for heat protection.
Post #702132 13th Oct 2024 10:17pm
Rangie4fun
Austria 2013 Range Rover Autobiography TDV6 Barolo Black
Interesting post! Always wondering what "codes" are used for Bank # and sensor #. Ist still doesn't make sense, but at least we can detect it now Rolling with laughter
Wel done Thumbs Up 2013 L405 3.0 TdV6 Autobiography Barolo Black (gone)
2004 L322 3.0 Td6 Vogue Cairns Blue (gone)
2000 P38 2.5 DSE (gone)
Post #702481 18th Oct 2024 3:11pm
