![]() | Home > My Range Rover > MY2019 SV Autobiography Dynamic |
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 189 ![]() ![]() ![]() |
Very very nice! |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 635 ![]() ![]() ![]() |
Looks a peach |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16400 ![]() ![]() ![]() |
I believe I read somewhere that petrol 405's are not rated for roof boxes? Worth checking into sir... ![]() |
Inigo Member Since: 15 Jan 2014 Location: Kent Posts: 55 ![]() ![]() ![]() |
I also heard that from the saleswoman at my first test drive. It made me panic a little, as that means Ski/snowboard runs are no longer possible and I should have kept the discovery!
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3811 ![]() ![]() |
They are probably just covering themselves incase anyone does 155 mph with a roof box which I suspect wouldn’t be a happy ending! Just stick below 90 and it should all be ok - it’s a big thing to have on the roof at excessive speeds… 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Twas only making you aware as them Suisse & French Police can be quite clued up on Reg’s… The last thing you need on the side of the road I’m guessing… 👍 |
Yes, OK, fair point, thank you. Perhaps I will try to find something definitive in case of a roadside discussion or, if needed, change my plans. |
I've had a look at roofboxes, to see if I can find anything written down. Nothing in the handbook.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35821 ![]() ![]() |
the v8 petrol body should be the same as the diesel versions so i cant see what the problem could be...
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3945 ![]() ![]() ![]() |
The only thing I've read relates to opening the roof with a box on, apparently you cant. Doesn't detract from the fact that you have a stunning car. Geoff |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2717 ![]() ![]() ![]() |
Very nice indeed , I’m a few weeks ahead of you ownership wise , they are mega .
I bought a boot mat secondhand from ebay, but it was the one for executive seats and with the bit that also goes in the cubbyhole on the driver's side. I think the part number is VPLGS0437.
