Home > General > I didn't know, did you?
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Having my 2011 4.4 for the last few months, I've only just found out that when you apply the handbrake when waiting at lights, junctions etc etc, you don't need to manually release the handbrake when you are ready to move off. Just touch the accelerator and it automatically releases it for you and off you go. Who'd of thought eh? I love finding out new things on the fatty that I never knew about.
Post #702397 17th Oct 2024 6:53pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Works on a hill start too. Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #702398 17th Oct 2024 6:54pm
Barmybrummie
That's exactly how I found out, being in the valleys full of hills. Put handbrake on a steeple hill junction, forgot I put it on as I was there a fair bit and accelerated to pull out and it moved off with no bong. So I tried the same again at some lights and thought what a result.
Post #702400 17th Oct 2024 7:08pm
mjdronfield
I like to take it off manually, just me….. the car has a feature where if you come off the foot brake it holds pressure for a bit so you can get on the throttle without rolling back. That’s separate to the hand brake, but that prob does a similar thing to. Some clever stuff going on, most of which is probably to assist off roading.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #702403 17th Oct 2024 7:30pm
GraemeS
Australia
Not just you who prefers to release the park brake manually.
The hill-start hold feature is specifically for use such as taking off from the lights.
Post #702411 17th Oct 2024 8:36pm
Barmybrummie
I didn't even know it had hill hold feature either until you guys told me. I just thought it was the characteristics of it being an auto of not rolling. I have been using the auto release since I found out it can do it. Am I just being lazy not moving arm to do it myself? Rolling Eyes
Post #702428 18th Oct 2024 7:47am
mjdronfield
I’m not keen on that little time period where you press the throttle and the handbrake is still on. I’m sure it’s fine and can also work that way, as indeed does, but I don’t like keep doing it. In the same way that when I park up, I put the handbrake on with my foot still on the brake, gearbox into N, foot off brake (weight of car settles on handbrake) then I select P. I don’t like the weight of the car hanging on the gearbox, as it were…. But then I’m a bit set in my ways 🤣. Some folks just use P and never use the handbrake, not for me….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #702434 18th Oct 2024 8:58am
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Sorry to appear like a smart ass, but I've known this for sixteen years!
The 3.6TDV8 was the same, so it's not just the later cars.
 The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #702437 18th Oct 2024 9:44am
Barmybrummie
That's exactly what I do too Mj, like you I always put it in neutral then handbrake on. As I park on a slight incline outside the house I'm rather sure it will do it the world of good not resting on the gearbox in park. I always put it in neutral when I'm stationary at lights etc etc too. I was told many years ago by a very old school mechanic who did classic car restorations namely jaguar E-types, to put it in neutral when you are stationary so there's no unnecessary force on the gearbox, that was his number one rule with autos.
Post #702438 18th Oct 2024 9:45am
Barmybrummie
So only now you just tell us this info JMC lol? Anything else we should know about that you know that we don't? Laughing
Post #702439 18th Oct 2024 9:47am
JMC
Orkney Grey is the best (and fastest) colour. Whistle
Black interior outlasts all the others.
Removable towbar isn't removable if left attached for years.
3.6 Vogue seats are the most comfortable.
GAP tool is essential glovebox accessory for 4.4TDV8
Money isn't the most important thing in life. Wink The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #702440 18th Oct 2024 9:57am
Please leave a list of what you don't know and we will try to help..... Rolling Eyes Laughing Pete
-Click here for Thread-
Post #702446 18th Oct 2024 10:26am
Barmybrummie
We could be here all day if I did that haylands Laughing
There something else I've found out too, mine has follow me home reversing lights too. Now that's very handy.
Post #702464 18th Oct 2024 11:51am
PeteT80
If you have the handbrake on and the door is open it won’t automatically release.
Post #702484 18th Oct 2024 3:55pm
GraemeS
Australia
If you're using the brakes at the same time for any length of time then you're risking failure of the gearbox selector module. There's a 1 ohm resistor in the circuit for the rotory selector motor that is used to determine if the motor is drawing current by checking the voltage drop across the resistor. The resistor overheats if power is applied for too long, melting its solder which then stops the selector motor from working. The solder will crystilise if it almost melts then sets again which increases the resistance in the joint which causes the joint to overheat more quickly next time it starts to get hot.
Neutral + brake pedal needs to be for only short periods.
Post #702517 18th Oct 2024 9:01pm
