![]() | Home > Technical (L322) > 2004 door mirrors |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Not a guarantee'd answer, but I think that they are different, a 2006 'Facelift' car has power fold mirrors and I have been told that pre-2006 they did not, I have seen parts listed as 2002 to 2005 then a different part for the face lifted model, best check with a good supplier, like a site sponsor for info. |
RogueRanger Member Since: 03 Jan 2024 Location: Kent Posts: 117 ![]() ![]() ![]() |
Yes 2006 model year has a different door mirror.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
If you fit 2006> door mirrors to a pre 2006< model then you will also need the window switch pack from the same age car as the can-bus is different and if you electrically fold the mirrors with the old switch pack, only one mirror will fold in and one out! And you will never get the mirrors to sync... So fit the newer mirrors and the switch pack and all will be well sir... |
Isn’t that solved by taking one fuse out and replacing it when they are in the same place ie folded or out? Des
