Home > Technical (L322) > left/ride play in rear left wheel
mgrover
No,
Oh I see, I thought you mistyped tie rods.
I cut mine too and with it brand new bolt and toe rod arm was installed
Then all wheels aligned.
I checked all the bolts and tight. Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #702641 20th Oct 2024 7:19am
mgrover
jic i tightened the toe rod part that connects to the hub while the car was on the ground.
hasnt made a diff
realistically i need to get the car off the ground first i think to allow the slack to become obvious Its actually a sport Sad
Post #702748 21st Oct 2024 10:16am
GraemeS
Australia
The nut on the parallel shaft on the ball-joint can be tightened with the suspension at any angle due to the joint being a ball-joint, but not for the inner bush bolt where the wheel needs normal weight on it during alignment.
My aligner couldn't get the left wheel out quite enough by turning the bolt and was going to leave it with toe-in when I suggested using a pry bar to move the bush out further, which did the trick. The bolt heads and washers aren't a tight fit between the adjuster bumps.
Post #702750 21st Oct 2024 10:29am
mgrover
the inner bush is perfectly tight.
its the only thing that makes sense for play in the wheel at 3/9 clock.
i need to get a 2nd person to test the wheel while i look behind Its actually a sport Sad
Post #702751 21st Oct 2024 10:31am
mgrover
right so i lifted the car, checked the play again.
all gone. those couple of turns while on the ground must have sorted it.
also found a snapped exhaust hanger
but the noise still persists... Its actually a sport Sad
Post #702764 21st Oct 2024 2:20pm
