![]() | Home > Technical (L322) > Dropping out of first gear when cold? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1395 ![]() ![]() |
Was it happening before you had the fluids changed? |
Paddy X350 Member Since: 15 Nov 2023 Location: Wexford Posts: 54 ![]() ![]() ![]() |
Not sure to be honest, I'm just really starting to listen for things if you know what I mean, I haven't driven it a lot yet. Lets assume it was....
First check I would do is make sure oil level is correct in gbox.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1016 ![]() ![]() |
When the fluid is cold its high viscosity means it takes longer to return to the sump and, if the fluid level is low, the suction port in the filter may become uncovered allowing the pump to suck air momentarily. As dingg1 has already suggested, I would definitely check the fluid level first.
Thanks for the replies.
So I replaced the fluid and filter with genuine ZF and so far the problem has gone away.... All the best
Benji1 Member Since: 11 Sep 2023 Location: Perth Posts: 36 ![]() ![]() |
Are you sure that it is the gearbox and is the car losing drive or just appearing to lose power?. The whirring sound you are hearing could also be the primary turbo spooling. Sometimes in the morning with my 4.4 TDV8 if I am climbing a short rise under low power and I back off the accelerator a little, power will drop disproportionally and a audible whirring sound can be heard from the primary turbo. This is only momentary. Put your foot back on the gas and off she goes without any problems. |
Hi Benji1,
