Home > Maintenance & Mods (L322) > Does anyone have an extra load space cover bump stop ?
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
Hi there,
I had a bump stop fall off (see pictures) - passenger side. No chance anyone has one lying around?
Thanks
Alex
 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #702040 11th Oct 2024 11:47pm
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
Hi Alex,
I'm guessing that the only way you'll find one is to find a cargo cover that's damaged but still has that bump stop.
Since it's basically a hard plastic, you could try fabricating one yourself. You could try forming one out of a larger block of plastic and glue it in. If you have the ability, maybe 3D print one.
You could try searching places like eBay and wrecking yards.
Also check to see if the cargo covers for the L320 (Range Rover Sport) has the same bump stop. It might expand your search.
Good luck!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #702853 22nd Oct 2024 6:24pm
muddycharles
Thank you Larry! I was thinking about sanding a piece of plastic down - but the damaged rear cover (which should be cheaper) is a great idea 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #702854 22nd Oct 2024 6:31pm
