![]() | Home > Technical (L322) > Rear Shock absorbers L322 4.4 TDV8 Vogue SE 2012 |
Solentlife Member Since: 12 Oct 2024 Location: Ventspils Posts: 2 ![]() ![]() |
I have to replace the shocks at rear of my L322 and I have been appalled at the new cost of originals at over 1000 euros each !
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2762 ![]() ![]() |
I replaced mine at 108K kms with Bilsteins as the originals were totally worn-out. Just don't fit Bilstein rear air-springs if you use off-road height because they aren't long enough, being the shorter version fitted to earlier L322s. |
The car has over 290,000kms on it and one side is basically dead and other side is near dead .. the car floats on bumps. When JLR were investigating for a clicking noise under the car - which is transverse box when loaded - they noted the shocks were bad .. plus some bushes and a bit of rust ... My local Auto Service (JLR are 3hrs drive away and hugely expensive ... as they get all parts via Finland - Finland get from UK, add their mark-up then pass to Latvia who add their mark-up !!). I asked both JLR and my local about Bilsteins and they both said not compatible ... So back to the links I showed ... please note Latvia is in EU and any parts from UK are subject to customs fees 21% and clearance fees ... I usually ask Britcars.co.uk for anything I cannot get here ... they are generally very good. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
not at all the same. Late 2010-2012 are adaptive Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3381 ![]() ![]() ![]() |
Aerosus and Autodoc are in the EU. If you are ordering from the UK then try Island 4x4. OE rear shocks are Bilstein. 2012 TDV8 Vogue (L322) |
TorontoDee Member Since: 27 Sep 2022 Location: Toronto Posts: 82 ![]() ![]() ![]() |
Mine were leaking and replaced earlier this year with OEM Bilstein. Bought from lrparts.net in UK for a very reasonable price, delivered to Canada by DHL in 4 days. 2012 Supercharged L322 |
