Home > Technical (L405) > pdc/park assit
Page 2 of 4 <1234>
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
yes i do
Post #703194 27th Oct 2024 4:06pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
I was suddenly thinking volume turned down Laughing but obviously not the case if you get the tone and message. Do the distances change from 2.55 or are they static? L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #703196 27th Oct 2024 4:09pm
will308f
i will check when i get home
Post #703198 27th Oct 2024 4:20pm
will308f
got one question .......do the parking sensors use the same module as the park assist ????
Post #703203 27th Oct 2024 5:13pm
Kot
Presume you looked at the Workshop Manual in the Wiki?
And are using this diagnostic procedure? It's quite comprehensive starts with the basics dirt/paint on sensors, fuses /wiring etc. Then goes into the fault find list.
RANGE ROVER (LG), 413-13
PARKING AID
DIAGNOSIS AND TESTING
The first step A1 reads
When the parking aid system is activated, there is a vibration on the
parking aid sensor membrane. This can be verified by touching the
parking aid sensor face with a hard item such as a pencil, ball-pen,
small screwdriver, or fingernail. Ensure no damage is caused to
sensor painted surface
Down to step A12 which then confirms replace the Parking Aid Control Module
There is also a 54 page Description and Operation also in the 413-13 section which shows you all the sensor locations etc 2018 SE SDV8 4.4 Byron Blue
Post #703210 27th Oct 2024 6:25pm
will308f
to be honset didnt do everything but will be doing alot more investigating over the next week or so
Post #703377 29th Oct 2024 4:19pm
will308f
i am getting failed control module in live date on the gap tool .........will have a look when i find where it is
Post #703448 30th Oct 2024 7:45pm
Kot
The parking aid control module is located in the luggage compartment, behind the left quarter trim panel of the luggage compartment.
The PACM has two connectors which provide power, ground and HS (high speed) CAN (controller area network) chassis bus connections, front parking aid sensors and rear parking aid sensors.
Worth checking those connectors for loose wires etc 2018 SE SDV8 4.4 Byron Blue
Post #703458 30th Oct 2024 11:06pm
will308f
i did look on the right side where the second battery is (need to reset fbh remote got a new fob for it )
but didnt look on the left Thumbs Up will look there ............ill get there in the end
Post #703462 31st Oct 2024 4:28am
will308f
what colour are the connectors going into the control module ....there not black -purple and yellow are they by any chance ?
Post #703463 31st Oct 2024 5:09am
Kot
No idea what the colour of your removable connectors are. But here is the wiring diagram with the individual wires in the connectors showing their colours.
eg Ignition is GN-BN (Green & Brown)
https://www.fullfatrr.com/gallery/albums/u...%20AID.pdf 2018 SE SDV8 4.4 Byron Blue
Post #703474 31st Oct 2024 9:54am
will308f
just been looking at removing the parking aid module (as gap tool says it faulty ) do you have to remove
the rear seat and several trim panels just to get to it or is there an easy way around it ?
Post #703504 31st Oct 2024 3:28pm
Kot
Just remove the left quarter trim panel of the luggage
compartment. 2018 SE SDV8 4.4 Byron Blue
Post #703516 31st Oct 2024 5:54pm
will308f
right found it my god is it tucked away or what ,and don’t tell me to get to it i need to a dozen panel pieces?.
Post #703718 4th Nov 2024 12:32pm
will308f
what a faff just to get this out lol ….
Post #703720 4th Nov 2024 1:20pm
Page 2 of 4 <1234>
