Home > Technical (L322) > 2012 4.4tdv8 rear sensor - suspension fault
RMac73
Hi folks
Suspension fault warning message appeared the other day - gapIID says right rear sensor not operating and right enough the life values option on the GapIID tool confirmed this giving a reading of 0.0 so clearly it is foobarred....
But today going out to the RR I noticed it was down on the bump stops at the rear?
Same thing happened when I left work today - so had to raise the suspension to get it back to normal.
So is the bumpstop issue likely caused by the broken sensor? Or is it more likely an issue with the bag?
Cheers folks πŸ‘
Post #703319 28th Oct 2024 10:50pm
JayGee
Broken sensor will cause the suspension to drop overnight as the self leveling system will be confused. Best to buy a genuine part as there have been reported issues with pattern parts. Before you order one check the physical linkage and the electrical connector / wiring. 2012 TDV8 Vogue (L322)
Post #703345 29th Oct 2024 8:13am
Dijit
Scotland 2007 Range Rover Vogue TDV8 Java Black
If the ride height arm isn't broken, try running that wheel over a pothole to give it a thump.
Twice over the years I've set off on a long trip and 30 mins in my suspension went rock hard. A quick look on the sat nav screen confirmed which corner and a few potholes later it suddenly corrected itself and all was sweet thereafter. I've had the corner drop as well as raise itself to the max. In fairness it tended to happen when I hadn't been driving it for a few weeks. Rehab is for quitters!!!
RR 2007 3.6 TDV8 Java Black *
RR 2007 3.6 TDV8 Zermatt silver *
RR 2000 P38 4.6 Met red *
Mercedes 300TE 4-Matic *
Jaguar 420 (1969) *
Nissan 300Z
Citroen XM 2.5TD X 6
Bentley Continental R
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Am told the ones with a * are to be offered for sale! 😳
Departed
LR 1992 110 2.5TD
RR 2000 Holland & Holland 4.6 LPG
RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue
RR 2002 4.4 V8 Zambesi Silver
Post #703371 29th Oct 2024 2:10pm
RMac73
Thanks Jaygee and dijit - I might try disconnecting it and giving it a clean but not holding my breath - although it worked for the other side last week....
If i have to replace sensor- is it easy enough to remove the bracket that holds the sensor? Going to try that as I've heard its almost impossible to take it off in place.
Thanks again
Post #703389 29th Oct 2024 8:07pm
JayGee
Mine was intermittently faulty and I ignored it. It then failed and nearly left me stranded as the suspension collapsed. My advice is if it’s not the wiring or physical connector then replace it. I also now carry a spare front and rear sensor in the car to get me out of trouble. 2012 TDV8 Vogue (L322)
Post #703390 29th Oct 2024 8:38pm
