![]() | Home > Technical (L322) > Burning smell/Smoke coming from under the battery!! |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3329 ![]() ![]() ![]() |
Sure it wasn't the FBH? - what did the smoke smell like? 2012 TDV8 Vogue (L322) |
Tiprat Member Since: 05 Aug 2021 Location: Manchester Posts: 101 ![]() ![]() ![]() |
Thanks for the speedy reply, it was white smoke and now you’ve said that no real burning, plastic, acrid smell, so maybe…..
The FBH activates automaticaly when the temperature is low. AFAIK it's 5 deg but not 100% 2012 TDV8 Vogue (L322) |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7994 ![]() ![]() ![]() |
Yes, will automatically come on to aid heat up of the coolant on a cold morning. The bit where you can set it to come on or activate with a fob is just additional functionality.
Ok guys thank you for your replies, and RobsterPC for posting his topic after mine the smoke looked the same, so I'm going with the FBH, although the outside temperature according to the RR was 11c.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 845 ![]() ![]() |
My handbook for MY11 says FBH will operate at <15 degrees |
From the Workshop Manual…
