Home > Maintenance & Mods (L322) > 8 speed ZF - Power Flush vs. Sump off and filter replacement
RangeAnxiety
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
I’m collecting my (new to me) L322 4.4 TDV8 in a few days time. It’s my first Range Rover, but far from my first older car.
I’d kept some of the budget back to take the chosen car to a specialist once I’d got one, knowing that I’d want some peace of mind after taking the plunge.
The one I’ve gone for is on 95k, has a lovely full dealer history, and lots of invoices totalling up to much than I’ve paid for it. However, while lots of the usual suspects have cropped up, there’s no record of gearbox oil being changed.
Researching my local specialists, I’ve enquired about the costs of a power flush. Two of the most helpful conversations I had did end up contradicting each other though and it’s left me a little stumped.
Specialist 1 said: Don’t bother with power flushing. All you do is push oil through the existing filter. The proper way to do it is to remove the oil, the sump pan, replace the filter and refill. The estimate for that job was £800.
Specialist 2 said: The filter is just made of metal coil in that gearbox and only designed to stop anything big. A power flush is perfectly fine and he’d done hundreds of them. The price I got on that was £360.
Aside from the obvious cost difference, and my apparently incorrect assumption that a power flush would be more expensive than a filter change, I’m not 100% which direction to go in now. I’m aware I’m not going to get consensus from a forum, but I’m keen to hear some owner thoughts… What do you think? 2011 L322 4.4 TDV8 Vogue
1999 Mercedes R129 SL
1995 Peugeot 106 Rallye
Post #703505 31st Oct 2024 2:32pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
True that the filter is a fairly wide mesh
Lifeguard 8 is fairly expensive- £25 a litre is an average price, and you need 6 or 7 litres for a drain and refill
Drain and refill only changes ~60% of the fluid in the gearbox. A power flush heats the gearbox / fluid up so that a complete fluid change can happen, which takes 12 litres
Sump (which contains filter) can be bought from a sponsor - advanced factors. I think around £150 pounds
Labour is 2-3 hours
There are cheaper alternatives to Lifeguard 8 - i think Bodsy uses an alternative
I have had both normal drain and refills and power flush done on mine.
I don’t think ZF recommend a power flush, but i noticed no adverse effect on mine.
Specialist 1 price looks expensive
Specialist 2 price looks cheap - is this with sump / filter replacement and with lifeguard 8? Anyone know what bodsy charges? I think bodsy is quite close for Worcester?
If yours has had no gearbox fluid change, I would get it done. I change my fluid now every year (drain and refill) and change the sump / filter every second year.
I am now on 125k miles.
First gearbox service was done at 30k miles, then 60k miles….no gearbox issues so far.
Post #703508 31st Oct 2024 2:55pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
At 60k miles I went through the process of dropping the oil and refilling 3 times over the course of two weeks, driving it circa a hundred miles between each oil drop. On the final drop I also then changed the filter. The oil went from black to almost bright green as the new oil was over the course of the process. I would estimate I have changed 90% or more of the oil and given it a good flush through.
I bought 20L of the correct oil from Smith & Allan. Oil was just over £100 and I used a genuine filter that was £120.
It drives super smooth and felt that it was a job definitively worth doing. It’s not a hard job to do if you are even slightly competent with the spanners.
I would certainly change the filter though, and gives a good opportunity to inspect for sludge, debris etc.
Post #703523 31st Oct 2024 7:50pm
mjdronfield
Get in touch with Bodsy. He does megaflush. I had that done in March, with both diff oils and transfer box oil. £500 odd. Can’t go wrong.
Search Bodsy on here….
Obviously folks have done various methods and will have their preferred approach. Up to you. Imagine any option is better than leaving it. Should be done at 10 years old according to ZF.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #703526 31st Oct 2024 8:16pm
JayGee
Whatever you decide to do I’d recommend it involves genuine ZF oil. IMO ‘flushing’ is unnecessary and simply replacing a good proportion of the oil with genuine ZF fluid and replacing the pan is enough on these boxes which are very reliable and will usually outlast the rest of the car. 2012 TDV8 Vogue (L322)
Post #703527 31st Oct 2024 8:58pm
Fox889
I’ve had two mega flushes, one at 82k when I bought her 5 yrs ago & then had Bodsy come down to the sticks this year & had another mega flush done at 105k. Overkill? Probably, but for piece of mind 99% of the oil is replaced via a mega flush.
You have to go with your gut feeling, simple. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #703537 1st Nov 2024 8:00am
JayGee
I don't trust 'gut feelings' when it comes to car maintenance but whatever makes you happy Very Happy
BTW - Does Brodsy use genuine ZF fluid in his Mega-flush? 2012 TDV8 Vogue (L322)
Post #703538 1st Nov 2024 8:18am
maz
Scotland 2011 Range Rover Vogue TDV8 Bonatti Grey
Did my filter replacement a few weeks ago, easy job and not worth paying £800 for. I dont really see the point if you arent replacing the filter. Also there are magnets on the filter base and will most likely have a thin film of metalic sludge on them so you are replacing those magnets as well and helping them perform better in the long run. The flush is just an oil change. 2011 4.4 TDV8 Vogue Grey/Ivory
Post #703541 1st Nov 2024 9:48am
DrRob
Just use Bodsy and be safe in the knowledge that he knows what he's doing and has done literally hundreds of them.
He's mobile out of Telford so not far from you...
I had my 8 speed flushed twice by him. Perfect Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #703561 1st Nov 2024 1:18pm
Rambles
Anxiety…
Why not take your RR to a ZF service centre?
Solihull…Walsall aren’t too far from Worcester
Post #703562 1st Nov 2024 1:22pm
Apache
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
https://www.advancedfactors.co.uk/lr065238...8462-p.asp
It's easy enough done, took me maybe an hour under the car, then went and did some other jobs while it cooled to check final level. Best if you have something like the IID tool to check temp, but could leave overnight. Just over £200
ZF don't manufacture oil so in a way its all rebranded. Happy with anything to spec.
Post #703636 2nd Nov 2024 10:40pm
