![]() | Home > In Car Electronics (L322) > Help please with car play |
Driyage Member Since: 30 Apr 2024 Location: Essex Posts: 44 ![]() ![]() |
Hi,
gavsfatty Member Since: 05 Nov 2024 Location: Burton On Trent, Staffordshire Posts: 6 ![]() ![]() ![]() |
Hi
I strongly suspect a ground loop; is there any portable mp3 player/phone that you can use to test the amp with an audio signal to see if the interference still persists ? |
Hi how would I do that |
Just plug the 3.5mm jack from the HU to the mobile device, not exactly sure what signal causes your amp to turn on etc... |
We are going way off the subject here, I’m looking for a fuse I can piggy back off instead of the cigarette lighter. |
Steveg Member Since: 06 Apr 2024 Location: Norfolk Posts: 57 ![]() ![]() ![]() |
I suspect you’ll still have issues if you use another 12v feed and earth point. There are a few RF filters built into the factory setup before the amp and radio unit. A ground loop suppressor should fix your issues. |
Not sure what this is or how I would fit one any idea please? |
