![]() | Home > Maintenance & Mods (L405) > Low SAPS 5W40 synth engine oil |
remote-trash Member Since: 08 Feb 2024 Location: Prague Posts: 3 ![]() ![]() |
Christian & Vera are running 5W30 in the queen. He use 5W40 in the 2.7 and 3.0.
Jorrocks Member Since: 13 Feb 2012 Location: Shropshire Posts: 55 ![]() ![]() ![]() |
As C3 spec is suitable for engines with EGR/DPF, I wonder how much more quickly my DPF will clog using it vs. C1 or C4, bearing in mind I never ever do journeys of less than thirty miles in either my 3.6 TDV8 or the new-to-me SDV8. Anything shorter distance is delegated to the petrol wheels!
Christian told me he’s going with the 5w40 in The Queen too from it’s next oil change. 2018 L405 4.4 SDV8 Autobiography 2010 L322 3.6 TDV8 Vogue SE, 171000 miles and counting…. |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 200 ![]() ![]() ![]() |
Looks like Christian & Vera have gone and done it - they’re running 5W40 C3 in the Queen.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1783 ![]() ![]() ![]() |
It depends on the age of your ”Queen” - Christian and Vera’s is pre-DPF.
Sorry Gremlin, but I think you’re mistaking the Queen (Christian’s L405) for their D3.
I know the difference between the D3 & L405 of course; I should have said “pre Euro 6”, not pre DPF.
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 402 ![]() ![]() ![]() |
Thanks for this.
I emailed S&A to enquire about a C4 5W40 some time ago, but they didn’t respond. V6 Vogue - “Less is More” - less to go wrong! |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
I know it;s a Toyota and they never brake down or do they |
For V6 owners worried about DPF's filling with ash more quickly on mid-SAPS oil it's worth noting that there are many companies out there that will remove your DPF and do a back flush clean on it to remove the ash and return it to as new performance for not that much money (Typicaly less than £500) 2012 TDV8 Vogue (L322) |
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 180 ![]() ![]() ![]() |
I am running Castrol Magnatec 5W40 C3 DPF oil and I have no measurable difference in regens/DPF soot etc as monitored on my GAP tool. I am hoping that I do have improved engine protection however - time will tell. Allowing for placebo effect, the engine does seem to run smoother/quieter.
@Alex1976,
No way of knowing the ash level but the car will throw a code when there is not enough capacity left. You can also check the pressure differential voltage and reference it with the workshop test procedure under different loads and rpm's AFAIK the upper limit is 1.5v. Mine goes to 2.5v with hard acceleration so I'm getting mine cleaned now it's getting near 180k miles. 2012 TDV8 Vogue (L322) |
