Home > Maintenance & Mods (L405) > Help - Suspension fault Green & Yellow
Page 1 of 3 123>
bigdave
United Kingdom 2016 Range Rover Vogue SE SDV8 Corris Grey
Well ive had my L405 2016 4.4 for nearly six months trouble free so i suspect im overdue a fault.
Firstly the red suspension warning with the roll over warnings. Stopped restart it then went yellow.
Codes read from my machine ;
C1119-09 Hydraulic Pressure Permanent
C1049-94 Front Axle Road PREssure regulating intermittent
C1048-94 Rear Axe Road PREssure regulating intermittent
DRM up the knacker?
It drives fine and goes up and down omn the suspension no problems, dunks or dongs.
Tad gutted but I went into ownership with my eyes open.
Anyone care to suggest a fault?
Thanks in advance.
Dave
Post #704302 12th Nov 2024 2:52pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
Check the ACE fluid level.
Nothing to do with the air suspension.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #704318 12th Nov 2024 7:27pm
bigdave
Thanks Chris,
Is the ACE fluid the DR Reservoir to the right side of he engine?
Forgive my ignorance im not technically gifted.
Cheers.
Post #704319 12th Nov 2024 7:30pm
ChrisJC
It's the reservoir on the passenger side about half-way back of the engine compartment. Yellow lid.
P38 - 4.6V8 HSE
Post #704322 12th Nov 2024 7:45pm
bigdave
Awesome - many thanks.
I will check tomorrow.
Cheers.
Dave
Post #704330 12th Nov 2024 8:17pm
It takes Cold Climate Power Steering fluid do not use anything else, unless it's compatible.
Shine a torch in the top and you will see where the fluid is, if it is low you may have a leak which needs looking at straight away... Thumbs Up Pete
-Click here for Thread-
Post #704341 12th Nov 2024 9:06pm
bigdave
Cheers Pete,
Yep Cold Climate PAS ordered and will top up on arrival.
Will let everyone know the result.
Thanks again.
Dave
Post #704343 12th Nov 2024 9:11pm
bigdave
Thanks Chaps - topped about 250ml of Cold Climate PAS and all is well. Bow down Bow down
Took it for a run and no warnings.
Im going to monitor over a few days to check for leaks.
Appreciate the help as i had a horror story in my head - new pipes etc.
Thanks again.
Dave
Post #704500 15th Nov 2024 2:06pm
ChrisJC
You've clearly got a leak somewhere for the fluid to be leaking out of, so I imagine some new pipes will be required...
P38 - 4.6V8 HSE
Post #704535 15th Nov 2024 7:44pm
From memory there is something to do with the ACE which gets changed at service every now and then? Reservoir from my recollection. There is nothing that can't be fixed with a hammer😜😜
Post #704545 16th Nov 2024 8:48am
bigdave
Im going to add it to the next service list at the indys next week.
Thumbs Up Thumbs Up
Post #704551 16th Nov 2024 10:34am
Prime spots for leaking pipes are in front of the nearside front and/or back wheels, the oil can leak onto the plastic guards and remain unnoticed for sometime....
They are 10mm mild steel untreated pipes (what did you expect on a £100,000+ car..!!!!) Thumbs Up Pete
Post #704559 16th Nov 2024 11:06am
Kot
It's the 5Y service on MY18 and the reservoir is changed as it has an internal filter p/n LR072550 about £90 on fleeBay
204-06
The reservoir contains the main filter for the system which acts on the fluid
returning from the valve block; a coarse nylon-mesh filter removes
particulate matter from the fluid before it is drawn into the pump. The
filter/reservoir assembly must be changed at the intervals defined on the
vehicle service schedule and if a system hydraulic component is replaced.
 2018 SE SDV8 4.4 Byron Blue
Post #704560 16th Nov 2024 11:27am
bigdave
Will look for that in it service records.
It has FMDSN til 90k.
Thanks.
Post #704639 17th Nov 2024 2:33pm
bigdave
Just to update you - its back.
Popped out this afternoon and boing the warnings came back.
Checked reservoir and its lost almost all of what i put in on Friday.
Mates going to get it on his ramps tomorrow to find the leak.
I also have it booked in still at the local indy for Wednesday.
All good fun!!
Dve
Post #704660 17th Nov 2024 7:34pm
Page 1 of 3 123>
