![]() | Home > Maintenance & Mods (L322) > Alarming............ |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3957 ![]() ![]() ![]() |
It's beginning to bug the neighbours, my alarm seems to go off for no reason - probably once every couple of days. I think it's something to do with temperature changes within the car - but I'm usually wrong |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
i read somewhere that the bonnet switch/sensor goes faulty or sticks ,might be worth looking at that especially if you've had the bonnet up lately.. |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Bonnet up lately! ![]() ![]() ![]() ![]() |
It happened again bang on 8:00am and it woke SWMBO
Is there just the one on the drivers side? Just for a test should I remove the plug and short circuit it or leave it open. Obviously a further complication would be if there is any resistive element in there but I guess not. It's all quiet now as she's go back to sleep ![]() |
boffhead Member Since: 19 Mar 2010 Location: Norwich Posts: 42 ![]() |
Had this on mine. Just disconnect the bonnet switch.
I don't want to count my chickens just yet but the alarm hasn't triggered since I disconnected the bonnet catch. Thanks Stan and Chris for the helpful suggestions. I have to say I would never have suspected it. I'll take it off and have a look at it this weekend and see if it can be fixed, serviced, adjusted - whatever, other than that I'll buy a new one.
how many chickens you got then geoff, see you dont know cos you aint counted them...[sorry,mad cow disease]
[quote="scarey"]how many chickens you got then geoff, see you dont know cos you aint counted them...[sorry,mad cow disease]
So disconnecting works - or at least seems to |
It's been a couple of weeks and although this is tempting fate it seems to be fixed without the need to change the switch or leave it disconnected.
sounds like the motor is running off the gearing or some of the teeth on the gears are missing hence the motor keeps running.. i disabled mine by using the RAC and found it ok getting in and out of the car, unfortunately the RAC only works up to 2005...but i sure i read that the steering can be disabled manually somehow..
