Home > Technical (L405) > Long term engine storage
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
I have a short block 4.4 SDV8 (448DT) just arrived direct from LR and I'm keeping it for a rainy day. It's crated and bagged but not airtight. It seems the entire unit has been coated in a fine oil, but does anyone have any recommendations as to what I can treat it with to inhibit rust long term. I'm thinking of something almost like a dry chain lube that will semi set once applied.
I'm sure there must be something out there for this specific application?
Many thanks L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #704438 14th Nov 2024 4:06pm
Lanoguard...??? Pete
-Click here for Thread-
Post #704448 14th Nov 2024 5:37pm
Nabbler
Wales
I’ve a friend who restores classic motorcycles and tends to rebuild the engines first as he can have many on the go at the same time. His method is to vacuum seal the finished engines with a few moisture bags. His storage in the workshop is typical that it’s an awful lot cooler than where the magic happens but I’ve seen some there for years looking as good as the ones at the front that have just been sealed 2025 SV P615
2021 SVautobiography Dynamic Black ( gone )
1997 C140 Mercedes Benz CL500
Post #704449 14th Nov 2024 5:45pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
How about this:
https://www.rust.co.uk/product/df-transpor...%20spirit.
Post #704467 14th Nov 2024 10:11pm
4RRS
That seems exactly what I'm after, it's showing as out of stock, but will give them a call to see leadtimes.
Post #704469 14th Nov 2024 10:18pm
4RRS
Vacuum sealing would be ideal, I'm just not sure I could get a bag that big and given the bulk of the block I'm not sure about the logistics of wrapping it successfully.
Post #704470 14th Nov 2024 10:20pm
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
Plus 1 on the bag. I have a small collection of classic motorbikes and I keep them in Vac bags when not in use. I wheel them in, throw in a couple of silica gell bags and suck the air out with a vacuum cleaner. The bikes are the same when I wheel them out, sometimes after a year or two. The only drawback for me would be that if I had a brand new TDV8 engine, I'd want to look at it...... every day. Cool
They're called 'Vac Bags' and come in several sizes.
Post #704486 15th Nov 2024 9:19am
