![]() | Home > In Car Electronics (L322) > No sound no dsp |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626 ![]() ![]() ![]() |
I think the radio module has a fuse of its own, on the unit itself. I could be mistaken but perhaps worth checking ... Also, provided you've sorted the issue, I would avoid replacing the stock head unit as you'll lose trip computer, slave clock etc. Instead of fitting an android I would try a solution that plugs in lieu of the CD changer and / or fitted a BT module. There are several other upgrades for the radio, TV tuner and Navi modules, the latter being likely the cheapest. A MKIV unit will cost you less than £200 and a 2019 map DVD another £15. Just throwing ideas |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
The DSP (or any of the units) will only appear in white on the screen if they identify themselves on the iBus. It’s not a fibre system on the early BMW based cars. There is a specific wire for the iBus. Can’t help much further I’m afraid.
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1040 ![]() ![]() |
Thanks guys iv tried all the usual suspects I know the dsp amp.is not identifying its self on the system hence no sound. No Bluetooth module fitted.
