Home > Technical (L405) > Parking brake actuator replaced under LR warranty ? - Yes
lambo911
United Kingdom 2016 Range Rover Autobiography SDV8 Barolo Black
Hi,
I had a parking brake warning come up the other day and it took a few attempts to get it to release.
The car has been into the MD and both of the actuator casings have cracked around the lower mounting screw and water has made its way in.
The warranty is refusing to cover it because it is a failure caused by water ingress, but surely the casing failure happened first and therefore that should be covered ?
Has anyone managed to get them done under the LR warranty ? They want £1,160 to replace both !
Cheers
Richard
Offside
Nearside
 2016 AB SDV8 Barolo black - Sadly sold
1995 RR Classic - Ex Police car - Now Sold
1994 RR 4.2 LSE - Long gone
Post #704516 15th Nov 2024 4:44pm
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
Cant say whether warranty should cover or not but even if they dont that price quoted is obscene. Just a quick Google shows the parts are relatively cheap
https://www.lrparts.net/lr036573-parking-b...-2016.html
https://www.britishparts.co.uk/range-rover...r-lr036573
and I dont think they are much of a job to actually replace. _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #704517 15th Nov 2024 4:55pm
lambo911
I will do it myself if they won't cover it.
I have added another photo to my post showing the nearside one where you can see a crack between the fixing bolt and the main body.
It's a chicken and egg question.. which came first the water getting in or the crack ?? 2016 AB SDV8 Barolo black - Sadly sold
Post #704518 15th Nov 2024 5:02pm
ReggieMac
As far as the warranty is concerned I am pretty sure that they will always say it was the water ingress first that subsequently caused the cracking but common sense would suggest that it is clearly the other way around. Rolling Eyes _______________________________________________
Post #704519 15th Nov 2024 5:07pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Main dealer strapped mine up for a year with cables ties and didn't tell me so it was out of warranty before i realised there was a problem and they failed, then said it was water ingress and duly emptied my wallet. I think you are on a hiding to nothing so get the best price you can.
Post #704527 15th Nov 2024 6:01pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
I got mine from here:
https://www.island-4x4.co.uk/parking-brake...40693.html
The problem is most likely that the aluminium boss which the actuator slides over has corroded and got larger. This bursts the actuator.
I cleaned mine up (particularly the o-ring groove) and put back together. An easy job.
There is some gymnastics with the pedals and handbrake lever to recalibrate them. More gymnastics to put the brake into 'service' mode in the first place.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #704534 15th Nov 2024 7:43pm
knwatkins
You can get aftermarket replacement actuators for less than £20 on eBay. Part no. LR036573 They are the same part as used on some BMW models part no. 34216794618.
I've had one fitted on mine for over 2 years / 30k miles and it's still going strong. 15 mins to fit on the driveway yourself. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #704538 15th Nov 2024 9:24pm
JCW
As Kev says above, I’ve also replaced these on the driveway using aftermarket parts, it’s not a particularly difficult task. Jonathan
2010 L322 5.0 SC Autobiography Black
2007 Defender 90 XS Hardtop
Post #704540 15th Nov 2024 9:31pm
knwatkins
Just make sure to check before buying your parts because some have the square electrical connector and some a rounded one....
part LR102237
part LR036573 Kev
Post #704541 15th Nov 2024 9:38pm
Gremlin500
Yes, don’t get it wrong:
[img]https://www.fullfatrr.com/gallery/albums/userpics/24757/IMG_0516.jpeg[/img]
[img]https://www.fullfatrr.com/gallery/albums/userpics/24757/IMG_0510.jpeg[/img] V6 Vogue - “Less is More” - less to go wrong!
Post #704543 15th Nov 2024 10:42pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
What a good business, invest 60 GBP, one hour and write a bill from 1.100 GBP, like Bitcoin trading Wink)
It's the same here in Germany, the official dealer only makes money from his stamp on the invoice and the intimidated victims who would never trust such a forum run there and pay any price. L405 SDV8 2017 + Lancia Flavia Coupe 1964 + L322 TDV8 2011 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #704554 16th Nov 2024 10:55am
lambo911
Has anyone actually been successful in getting the warranty to cover it ? If you can show the casing failed first then they can't argue it was corrosion ? 2016 AB SDV8 Barolo black - Sadly sold
Post #704733 18th Nov 2024 6:26pm
lambo911
Well, I have had a result ! Very Happy
The warranty company have now agreed to replace the one actuator under warranty after I called them to argue that the casing failed first. Their argument had been that the fixing bolt had corroded and expanded, causing the case to fail but the dealer said the bolt was ok.
They have only replaced one as only one was causing an issue so I will take the other one off, lubricate it and seal up the casing so it will hopefully last a few more years.
The fixing bolt corroding may result in it expanding and causing the casing to crack so it would be worth removing the bolt greasing it up and fitting it back as a preventative measure. 2016 AB SDV8 Barolo black - Sadly sold
Post #705641 28th Nov 2024 3:45pm
