![]() | Home > Technical (L405) > Reccomend recon engine 2017MY RR Autobiography SDV8? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
Not as much of an issue on the V8, but a few comparatively recent reports been coming in around bearing failure. Crank snapping is much more of an issue on the V6 with issues being reported for a few years.
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 426 ![]() ![]() ![]() |
These guys might be worth a try.
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 327 ![]() ![]() ![]() |
First of all, my sympathy and condolences for this engine failure. On the subject of engine repairers, I can only speak for Germany: there is no reputable repairer here, and I don't know of any SDV8 that has gotten far with a repaired engine, but if it is defective again within the "warranty" it is always due to the wrong oil, too short Intervals or driving errors are referred to. I can only advise everyone from experience to sell the defective car or for a visible one!! Converting an accident car to a used engine, everything else is nonsense. L405 SDV8 2017 + Lancia Flavia Coupe 1964 + L322 TDV8 2011 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782 ![]() ![]() ![]() |
Selman Motoren are quite well respected in Germany for the 448DT I believe...
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 406 ![]() ![]() ![]() |
That seems a very good shout as the second one has less than 50,000 miles and is side structural. Even after taking everything you need out there’s still a load of stuff you can sell from that and scrap the shell. If you’ve got somewhere to store the donor whilst it’s being broken up it could end up almost a free engine swap. J |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 442 ![]() ![]() ![]() |
Second link is to a 3L SDV6, not going to help our OP. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
Yes and no, depends on what engine you go for and what model year! The 306DT (SDV6) engine is still available from JLR as short block, strippped or full engine, as this was a joint project with PSA (Ford, Peugeot & Citroen). The engine is used in many models of the respective manufacturers although all are not interchangeable, due to mainly different engine mounting points (they were transversly mounted in some applications). The 448DT (TDV8/SDV8) fitted to the FFRR L322 & L405 are no longer available as this was originally designed by Ford (when they owned JLR) for the Ford F150 pickup, as they thought they could market a diesel version of the F150 to the US market. It was made at the Ford Engine plant in Mexico for this sole application, but once the bean counters at Ford reviewed the figures they soon realised that the $6K uplift in price for a diesel F150 would never sell due to the low price of 'gas' in the US. It then sat on the back burner for a while until Ford decided they needed a replacement Diesel V8 for their FFRR and they had just the engine sitting with no home. JLR (under Tata ownership) terminated the build contract with Ford in 2019 giving them 3 years notice that they no longer needed the 448DT (as it was replaced with the Ingenium range of engines in the latest L405's) hence the supply has now dried up. Jumping forward, JLR, in a bit of a mess with loads of buy-back failed V8 L405's contracted Ford to produce a batch of short blocks, however as the 448DT Mexico engine production line has now been dismantled they could not fulfill the whole order and therefore just supplied the components, these were then shipped to the UK and assenbled by Autocraft Drivetrain Solutions in Grantham. HTH L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 796 ![]() ![]() |
Has anyone ever asked Autocraft Drivetrain solutions if they could rebuild a broken V8? |
It’s a good idea but having had a quick look at the website I don’t think they are involved in work for the public, it’s almost certainly on behalf of manufacturers. Always worth a phone call of course but I wouldn’t be too hopeful.
Chef45 Member Since: 02 Jan 2024 Location: Hampshire Posts: 14 ![]() ![]() |
No, a good shout, though, thanks. |
Thanks SO MUCH, good shout!! I'd have to pay to have it taken out but at least, I'd know it came from the same car! |
Thank you everyone, this has been SO helpful. At least now I have all the options and know what I need to plan - I was a bit lost.
SS.Lyria Member Since: 01 Dec 2016 Location: London Posts: 269 ![]() ![]() ![]() |
I’m assuming aftermarket warranties for SDV8’s are now either going to be very expensive to buy or not available at all.
I'd be interested to know how you obtained a LR factory unit as none have been available for nearly 3 years. I'm seeing the last price for a full engine at over 23k. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
