![]() | Home > Technical (L405) > Diesel Pre-Heater blowing cold air |
| rattly Member Since: 15 Oct 2016 Location: Cotswolds Posts: 45
Hi all,
Hi,
| 4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 442
Got you!
Thanks for this...
| E500 Member Since: 10 Sep 2024 Location: Hertfordshire Posts: 87
It takes ages for it to actually warm up. I turned mine on this morning and 20mins later I could see it starting to defrost / melt the snow on the windscreen. By the time I got into the car ~25mins after turning it on, it was toasty. But it doesn't do much for the first 10mins or so, in my experience.
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764
Just to add, I thought the heater initially heats the water and that circulates round the engine to heat that.. only when that water is up to temp (whatever that is) it diverts the warm air to the cabin.
| hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 157
It's kind of the other way around. Normally during pre heat the heater coolant circuit is isolated (by the changeover valve) from the engine coolant circuit, so that only the heater circuit is heated by the fuel burning heater. However, if the temperature is less than -20 degrees C then the changeover valve will remain open, so that the engine is also warmed, to aid starting, and the heater blower won't start until the coolant is "above a suitable threshold". |
