Home > Maintenance & Mods (L322) > V-Power Diesel
JayGee
V-Power Diesel
I'm on my 3rd tank in a row now and noticing a definate improvemnt in low rpm power pickup. Previously the only changes were the lack of diesel clatter and sickly exhaust smell in the mornings. No MPG gains or increased DPF regen intervals which was the reason I tried it. Not sure if the drivability improvements after 2 tanks are the result of the cleaning addatives or the ECU adapting to the improved combustion efficiency ( likley both) but I'm not going back to ordinary diesel. Some say that ordinary diesel + addatives are just as good but it's a lot of faff when filling up. 2012 TDV8 Vogue (L322)
Post #705020 21st Nov 2024 11:20am
Rudyard1
I only ever use V-Power or BP Ultimate diesel in mine. Always have - make sure you have the apps and the points you get through the use makes up for the slight increase in cost as you always collect points etc and convert to coupons. 2007 Range Rover Vogue 3.6 TDV8
Post #705029 21st Nov 2024 12:05pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
I use Esso now
Every third tank i use supreme
For the benefit of extra detergent
I notice zero difference in performance
I do notice £10- £15 pounds a tank per refill
You can easily add redex etc…to each tank full if you want
Post #705190 23rd Nov 2024 7:31am
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I am a big fan of V Power and use it almost exclusively however I am getting increasingly annoyed at the price difference as it feels like we are being ripped off. Currently my local Shell garage has diesel at £1.43 whereas V Power is £1.69. I do feel that V Power has some actual benefits and is worth more, but 26p per litre, or around £20 on a full tank just seems excessive. So I am looking at additives and just fill up at Tesco for £1.39 per litre.
Post #705191 23rd Nov 2024 8:02am
Fox889
I know this will open a can of worms, but I use Archoil in my Alfa diesel, has decent reviews. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #705196 23rd Nov 2024 8:32am
Alex1976
I have just been looking at this as an option:
https://worldoflubricant.co.uk/collections...1519686698
Reputable brand and I like the ‘single shot’ can rather than messy measuring/dosing. It works out about half the price of V Power.
Post #705197 23rd Nov 2024 8:52am
JayGee
If V-Power also has a GTL ( Gas to liquid ) synthetic fuel addative as well as a cetane booster it's not the same as just normal fuel + addative. I personaly don't mind £20 extra per tank for the power delivery refinements I'm getting which definatly took 3 tanks on a row to see the difference so not convinced alternate fills with ordinay diesel are worth it either. 2012 TDV8 Vogue (L322)
Post #705198 23rd Nov 2024 9:23am
supershuttle
6 yrs on Tesco diesel and it runs just as good as it ever did. Oh and as I fill up every fortnight I've saved well over 2000 quid (surely not that much, my maths may not be correct) - not that it matters Very Happy. Geoff
Post #705210 23rd Nov 2024 11:42am
francy
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
my wife car use supermarket diesel and ended up garage bill 12 quid all blocked up with gunk even the garage owner said not to use . Big Cry
Post #705240 23rd Nov 2024 4:38pm
Alex1976
This is an interesting watch
?si=1b1FaTc2_1yyt1LE
Apparently there is very little benefit to premium diesel over standard. Petrol is different though.
I am going to take his advice and just use standard diesel from any high volume and well maintained fuel station.
Also interesting comment that the best way to deal with diesel in the green agenda is to replace it with HVO rather than electric or hydrogen etc. trucks are already widely using HVO so perhaps also a solution to diesel Range Rovers?
Post #709252 15th Jan 2025 8:16pm
JayGee
My take from that is to continue to use V-Power Diesel. 2012 TDV8 Vogue (L322)
Post #709279 16th Jan 2025 8:46am
Eastsoutheast
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
I use premium diesel but also add a 50ml Censored of Miller's Diesel Max every time. 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #709384 16th Jan 2025 8:56pm
Gremlin500
I thought this was all Hokum to be honest, however I’ve recently changed my mind.
A mechanic acquaintance with decades-long experience working on LR and farm vehicles, told me not to use cheap diesel, so I thought I’d experiment. I keep a weekly OCD log of fuel/cost/miles/mpg (using the “brimming the tank” method), and due to little variance in the mostly urban journeys made, almost always got between 27.5 and 28.5mpg over the past 3 years.
I was quite surprised when my last two fills both returned 31.5mpg on the Super Diesel, so an improvement of 3.5mpg, -that’s a 12.5% improvement!
Has anyone else found similar?
So for now, it seems the Super is no more expensive, and may keep my fuel system in better shape, and give a bit more power when needed, it seems a no-brainer. V6 Vogue - “Less is More” - less to go wrong!
Post #717144 30th Apr 2025 9:21am
supershuttle
As regular forum users will know I am a supermarket diesel is fine sort of guy (also it's the easiest for me to get as Tesco is just across the road). However recently I put a couple of tanks of V-Power in and the car seemed to run better, as for better fuel consumption I wouldn't know or care. For every tale of how good V-Power is there is always a story that starts with "I know a bloke......" all the first hand experiences on here reassure me that V-Power is not a bad thing so when I am on a longer trip and need to fill up I use it. If cost were an issue I probably wouldn't be running a Range Rover. Geoff
Post #717156 30th Apr 2025 12:23pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
I have always run all of mine on Super Unleaded and Super Diesel, is all in the head probably but i feel better for it......
Post #717172 30th Apr 2025 4:23pm
