![]() | Home > In Car Electronics (L405) > Speaker noise after heavy rain |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1473 ![]() ![]() ![]() |
I would be very concerned the sunroof drains have blocked/failed and filled up the rear footwell, have you checked the sunroof drain points, assuming you have a sliding roof. I think there is plenty to fry under there. |
Benner91 Member Since: 18 Oct 2015 Location: Belfast Posts: 87 ![]() ![]() ![]() |
Hi thanks for responding we’re are the drains located thanks |
Open the sliding roof, look about 4inches towards back of the gully you will see a small hole one both sides.
If it is that then you need to sort asap as damage will be massive if it continues.
Thanks I will do this first thing tomorrow |
Hi does anyone know and have photos of were the sun roof drain pipes exit the car I can’t find them anywhere
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 835 ![]() ![]() ![]() |
It's under the rear wheels cowl, you can see in the video at min 5:24 |
Thanks ☺️ |
