Home > Technical (L322) > Heated seat fuse
JW911
Heated seat fuse
Both heated front seats seem to have stopped working. Switch lights come on but no heat. It’s a 2012 with heated/cooled front seats.
As it’s both, I’m assuming the fuse. Which one please and what capacity? 2021 3.0 P400 Vogue
2012 4.4 TDV8 Westminster - gone!
2007 3.6 TDV8 Vogue - gone!
2003 4.4 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #705461 26th Nov 2024 10:48am
pcourtney
Fuse 29 and 33 from memory, 20A
Post #705482 26th Nov 2024 3:06pm
JW911
Thanks. Good guess!
Not the fuses though. Drivers side only as it turns out.
Any ideas before it goes in? 2021 3.0 P400 Vogue
Post #705492 26th Nov 2024 6:14pm
pcourtney
I have the same problem, when I scan with the GAP IID I get this error
DCSM - Drivers Clim Seat
U0140-00 (2F) Lost Communication with body control module
and a lot of good info below in this mammoth thread - it might also help
https://www.fullfatrr.com/forum/topic44946.html?highlight=u0140
Post #705501 26th Nov 2024 9:08pm
JW911
Now properly confused….
I pulled the back off the seat, as per the video. Nothing wrong with the unit. I checked the fuse (29). Fuse is good.
I thought I’d swap the fuses between the front seats to make sure. No change. However, when I pulled the fuse to the passenger seat (fuse 33), the heater and fan continued to work as if it wasn’t part of the circuit.
Help…..
If it is the comms issue with the body control module, does anyone near Reading/Basingstoke/Camberley have a Gap IID I could plug in please to hopefully reset it. 2021 3.0 P400 Vogue
Post #705830 1st Dec 2024 3:46pm
pcourtney
sadly no matter how times I reset the fault/error with my GAP IID it does not resolve it
Post #705854 1st Dec 2024 8:12pm
JW911
After all that, it was the Peltier sensor. I found a brand new unit on eBay and fitted it myself thanks to the instructions on the long thread. Bow down
Whole job £339, thanks to a £15 eBay discount. 2021 3.0 P400 Vogue
Post #706230 6th Dec 2024 11:27am
