![]() | Home > Technical (L405) > Adblue DEF overhaul |
E500 Member Since: 10 Sep 2024 Location: Hertfordshire Posts: 87 ![]() ![]() |
Yuck, nice job. Is that just crystallisation you can see in the pics?
Viggy17 Member Since: 14 Oct 2024 Location: London Posts: 34 ![]() ![]() ![]() |
Ha ha well spotted, yeah it’s my sons. I like to have a blat in it when I can, it’s a good laugh, like a roller skate. Yeah the white stuff is crystallised adblue. Toothbrush dipped in vinegar removed it easily |
So a Disappointing test drive result. I first got the insufficient reductant quality error , cleared that and then got the dreaded no engine restarts countdown. I didn’t have either in the dash before 😩
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1434 ![]() ![]() |
The handbook does say
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 236 ![]() ![]() |
Was the system primed correctly following reassembly? There is a prime and pressure test routine that should be run.
Thanks that’s useful to try out. I did take it for two decent runs but I can’t recall if I started three times. But when I get back I’ll try that three times for perhaps 30 seconds each. I though I was mitigating this kind of nonsense by draining and refilling without powering anything up but who knows, eh?! |
Thanks. No, I didn’t know about priming and pressure testing and I don’t have a GAP tool to do it so this could be it. The injector is perfectly clean, the fluid is correct spec and fresh. I’m hoping it’s not the other issues you mention as it was working before, well I didn’t have dash errors so assuming so. Maybe you can answer this if poss, I first filled up with 5L and it showed 500m range on the service menu, I put another 5L in and it stayed at 500m …. Why?? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1880 ![]() ![]() |
Because there is a fault in the system. Needs a reset, or codes read at a minimum |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
As Mikey says you need to reset the system.
Thanks Gents.
Snap on diag is woeful with anything JLR... |
From what I could see Mikey I have to agree, it didn’t appear to have the ability to do, for example, pump priming or force a spray.
