Home > Maintenance & Mods (L322) > Fuel guage playing up
JayGee
Noticed yesterday the fuel guage had dropped in the morning and it took a few hours before it bounced back to where it should be. I've looked at the issue and it seems there is a known issue and a technical repair procedure which I've downloaded but it looks like a messy job. The real danger is of it happening again before I can find time to fix it and it causing an engine shut down so as an interim fix I'm going to look at splicing in an a resistor to fool the ECU to keep the car running.
Interestingly I had this issue on my Audi and I kept it going by lifting the hatch in the floor and hitting the housing which kicked it back into life. This was a 4x4 with a tansmission tunnel that the tank was formed over an had a lift pump to equalise the levels on each side. There was also advice from owners not to over fill the tank by adding more fuel after the pump's autostop has activated. 2012 TDV8 Vogue (L322)
Post #705696 29th Nov 2024 11:07am
Shaun_
Hi JayGee
In case it helps I had exactly this problem and found the various posts you refer to detailing the known problem.
In my case, however, a wire in the loom that travels from the top of the tank under the drivers' side rear seat squab had worn through and was shorting. It's not too difficult to remove the squab and check the condition of the wires so may be worth eliminating first.
Good luck.
Shaun 2012 TDV8 Westminster in the New Forest
Also: Land Rover Series 3 SWB, Mercedes 280SL, Classic Mini race replica, VW Golf SV
Previously: Audi A8, RR TDV8 Vogue, Audi Allroad, VW Golf GTI Edition 30, Audi A4 Avant, A8, A4 Sport, A6, VW Golf Mk5, Bora, Golf GTI Mk3, Jetta Mk3, Passat, Jetta Mk1, Golf Mk1
Post #705796 30th Nov 2024 6:33pm
JayGee
Thanks Shaun I’ll get the carpet up and have a look Thumbs Up 2012 TDV8 Vogue (L322)
Post #705799 30th Nov 2024 8:37pm
JayGee
Sorry repeat post 2012 TDV8 Vogue (L322)
Post #705800 30th Nov 2024 8:38pm
tj196443
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
Hi Shaun, if you don’t fix it you the car will eventually think it’s ran out of fuel and shut down the engine. Plenty of posts on here on how to fix the wire in the fuel tank, can be done but can be messy. When I did it I found having as little fuel in the tank as possible made the job easier, as your working from above the tank through the access holes be careful you don’t drop anything in the tank. I snipped the offending wire and joined with a bullet connector. Had no issues since and that repair was a couple of years ago.
Post #705815 1st Dec 2024 10:23am
Baltic Blue
Do you need access to both sides of the tank or just one ?
Drivers or passengers ?
Post #705816 1st Dec 2024 10:55am
cass
When mine packed upon the middle of winter I got a variable resistor (from Maplins it was that long ago). I wired it to the sender unit wires under the back seat then adjusted it to show half a tank then waited for the weather to get better.
I ended up running it like that until the following August with no problems
Post #705828 1st Dec 2024 3:42pm
JayGee
Great idea Thumbs Up 2012 TDV8 Vogue (L322)
Post #705845 1st Dec 2024 6:43pm
sako243
There's also a connector in the tank that causes issues. I just opened it up and cut the connector out soldered and heat shrunk the wires. Ed
Post #705944 2nd Dec 2024 10:43pm
Old-un
United Kingdom 2011 Range Rover Vogue 4.4 V8 Causeway Grey
Slightly messy job really, I had the garage fix mine and saved quite a bit of money by making access to the tank easier for them. I pulled the carpet up towards the back of the front seats and tied it up round the seats exposing the sensor covers so they had easy access to them, the tension in the seats means they won't stay up on their own. This is after moving bits and pieces to enable the carpet to be lifted.
The mechanic removed the sensors and re-soldered the wires on the bench, plus shrink-wrap, refitted them leaving me to replace the carpets etc.
There was as expected a lingering odour of diesel for a couple of days but a sprinkling of cat litter on the carpet helped it disperse.
Doing this really reduced the labour cost to about just over an hour. RR owner
Post #706082 4th Dec 2024 2:16pm
sako243
I didn't find it a particularly messy job in the slightest. Made sure that the tank was pretty empty as I didn't know how far down the connector was.
I think I was all done inside an hour, folded seats up, lifted carpet and tied it around the seats to hold it out the way. Disconnected fuel lines, undid the locking ring and pulled the wires out. Cut one side of the connector out, stripped wires back, soldered them together heatshrink over that. Repeat for the second one and had also put a piece of heatshrink to cover both.
Job done after just dropping carpet back down, bolting seat retaining brackets in and voila. Not a difficult job in the slightest, nor messy if you're careful pulling the sender out. Ed
Post #706087 4th Dec 2024 4:21pm
Old-un
I always find working with diesel fuel to be slightly messy, sorry. RR owner
Post #706150 5th Dec 2024 1:21pm
JayGee
I much happier working with diesel than petrol in this kind of situation. No toxic vapours and no fireball risk. 2012 TDV8 Vogue (L322)
Post #706152 5th Dec 2024 1:58pm
Old-un
Very well. RR owner
Post #706159 5th Dec 2024 4:02pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
There is a very good thread on it here: https://www.fullfatrr.com/forum/topic46574.html 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #706163 5th Dec 2024 5:33pm
