![]() | Home > Technical (L322) > FBH not working, advice welcomed! |
FalconFlyer Member Since: 14 Nov 2021 Location: Crowthorne Posts: 4 ![]() ![]() ![]() |
Bump. Some advice would be gratefully received! |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1031 ![]() ![]() |
I'm don't know what that code relates to but try again with your gap tool prime it and try to run it I put an air line in my intake to force it to run and it eventually did and worked fine there after.
Thanks. Sadly the gap tool just gives error E3 for both priming and operating the FBH.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 700 ![]() ![]() ![]() |
I know one of the criteria to work is 1/4 tank of fuel minimum also outside temperature has to be below +5 (guessing now) might help you? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
No, in theory the GAP tool should over ride the temperature, particularly if all I'm asking it to do is prime.
