![]() | Home > Maintenance & Mods (L405) > Spot the problem! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
Try warming it up with a heat gun for a while, move quickly and keep feeling the panel, you don't want it hotter than your hand can take, then try pulling it off....
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1474 ![]() ![]() |
I had a similar problem with my previous MY2017 with a badly fitted front mudflap and discovered that the panel is in fact 2 seperate sections, the base and the body colour upper section. You don't need to warm anything up but having a set of plastic trim removal tools will help a lot.
Rex the RR Member Since: 15 Nov 2019 Location: Perthshire Posts: 43 ![]() ![]() ![]() |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 406 ![]() ![]() ![]() |
Hi,
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 393 ![]() ![]() ![]() |
Maybe cheaper just buying original as opposed to having to buy 10, here's the JLR link to them: -
Well spotted.
Actually, scrap everything I said, just noticed you’ve got an L405 - your profile says 2011 but clearly the photo is the later model. And it’s posted in the 405 threads |
Thanks for your comments guys, much appreciated. I think the parts l need are 219A38 but I'm not sure as it looks like l only have broken bits. I'l call the local dealer tomorrow or I may attempt to look at the other side tomorrow but in my experience, that's asking for trouble! Keep you updated on progress.
Nope, you don't "have to" heat it up but the idea behind it is pertinent to this time of year, if you pull them off in these cold conditions the panels are well known to snap...!! Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Yes Pete, you're absolutely right, in this weather it doesn't hurt to make them a bit toasty and more flexible |
