![]() | Home > General > Thinking about a 5.0 Supercharged L322, again.. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8714 ![]() ![]() ![]() |
They rust a lot, JLR were forced to use Tata steel so check tailgate, arches, rear of sills, subframe...etc Pete
Calcifur Member Since: 11 Nov 2023 Location: Angus Posts: 27 ![]() ![]() |
The pictures and description seem to suggest it is rust free. It's a long trek away from me so viewing will only be once I am pretty well decided.
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1026 ![]() ![]() |
Iv seen that one on the bay and to be honest wouldn't touch it with a barge pole. My mate just had a 5.0 in his garage that had an engine rebuild and it was leaking coolant like gods knows rattling it's tits off and those weren't even the worst of it.
3 owners on 14-15years. And FSH.
The rebuild was done by someone else it ended up at my mates garage due to the many coolant leaks missing hose clamps etc. He got it sort of water tight but that was as far as he would go I helped him source a bleed valve which had been previously broken off and hot glued back on. I mean hot glue on a coolant pipe bleed valve....like that will work.
That sounds like a |
more likely they skimped on paint prep and cavity sealing to save £££. All mild steel rusts equally well when exposed to air and water. 2012 TDV8 Vogue (L322) |
The first task for any vehicle I get will be a good rust treatment with lanoguard or similar |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 627 ![]() ![]() ![]() |
Like any car and particularly JLR you've just got to be lucky. There are many good ones out there but they're getting old and some have never been right from the factory. All you can do is the sort of due diligence you're doing; look properly when you go see; and try everything on the test drive.
These rot from the inside so it's often too late 2012 TDV8 Vogue (L322) |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 925 ![]() ![]() |
When I buy L322’s I always remove the lock release / number plate lights trim (2 x torx screws) which gives good access to spray a rust inhibitor into the internal cavity.
I have read about this approach before for the rear gate.
Can anyone advise on the current value of the 5.0 Supercharged FFRR?
