![]() | Home > My Range Rover > Another rescued L322 - 2011 5.0 SC Autobiography……Copart |
Salter121 Member Since: 20 Jun 2018 Location: Berkshire Posts: 128 ![]() ![]() ![]() |
Ran the ECU update/flash to version CH42-14C204-RTC - cycled the car a half dozen times and ran it to temp - no fault codes came up and did not go back into limp mode - yet live data still shows discrepancies - how can bank 1 and bank 2 be so out and it not throw up a fault code?
Last thing to test will be the wiring harness from the camshaft sensors right through to the ECU... while I have check, re-check and where needed fixed broken or badly repaired wiring to Bank 2.... I need to check the Solenoid-Camshaft profile switching-bank 2 cables to ECM... each camshaft sensor on bank 2 inlet and outlet share the same ground and voltage reference cables and with the P0345 and P0390 I am wondering if it might be one of these.... fact that it has intermittently worked could be down to a bad ground or short somewhere.... will test and maybe just run a complete new wire to each sensor and bypass the harness to eliminate as much as I can....failing that can't see it being anything other then an actual timing chain issue!!!!!!
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 390 ![]() ![]() ![]() |
Following this with great interest. What a huge amount of work. But what skill you seem to possess. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3263 ![]() ![]() ![]() |
I'd be interested to know if your chains were done using genuine LR parts or one of the cheap Chinese kits that you can buy. I read online that the cheap kits don't last 5 minutes which could possibly explain some of the issues you are experiencing. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
🚗 Diagnostic Journey: The Saga of Bank 2 Camshaft Sensors 🛠️
Finally getting around to finishing up some interior updates—replaced the old broken start/stop switch, and it’s made such a difference! Looks so much cleaner and feels great to have it working properly again.
Top work!
🚗 Range Rover Project: Everything Done So Far 🛠️
Thanks David....
I know these rear screens are not even HD let alone 4k....but nice to have the Fire TV wired into the rear AV.... Amazon, Netflix, and Apple TV is a lot more pleasing to the kids than BBC News (the only TV channel I seem to be able to receive) and my early 2000's DVD collection of Friends and Csi......
I have never replaced brakes before; even though I have been working on my own cars for years, I kind of always thoughts that brakes were a thing to leave to the specialists... however; anyone contemplating saving some money and doing your brakes yourself, I would highly recommend it - I was amazed at how straight forward to was, I always was a little scared of out...
Other than a couple of snagging issues the Copart rescue is pretty much complete now.... I won the car at Copart on 25th September - two and a half months from pretty much a wreck to what will be a wonderful daily driver for me for a good few years ahead.....Do I regret it? Put simply no; while I could have bought one for a lot less than it has cost me to sort this one; like I had before when I saved my 2011 L322 4.4 TDV8, you can't really put a price on that feeling of accomplishment from taking a car from what was a dead wreck, back to life........and when that re-born wreck has a Supercharged 5.0 V8; how can you not just smile ear to ear while your wife shouts at you from he passenger seat to slow down............ |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 203 ![]() ![]() ![]() |
Quite the transformation, it has been a very interesting thread to follow, I'm officially impressed.. |
That looks like it’s scrubbed up lovely in your last picture.
