![]() | Home > Maintenance & Mods (L405) > Help - Suspension fault Green & Yellow |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8815 ![]() ![]() ![]() |
I would imagine they are the same but best to check on Microcat in the WIKI... |
bigdave Member Since: 27 Jun 2011 Location: Cornwall Posts: 268 ![]() ![]() ![]() |
Thanks Pete.
Can i pull the fuse on the pump then and just use it for brief runs to keep the battery topped up and parts moving? |
Pump is mechanical so runs when the engine does, you could take it off but it would be a headache as you will need a shorter drive belt among other things... |
OK thanks bud. |
