Home > Technical (L405) > Will not go out of P!?!
JLS
Norway
What’s the odds getting the gearbox out of P if I disconnect the battery for a few minutes? It’s now stuck Big Cry
Known fault? 2016 L405 SDV8
1962 Series 2 a petrol
1965 MB 230 SL
Post #704856 19th Nov 2024 9:21pm
are you pressing the foot brake down enough?
or,
https://www.fullfatrr.com/forum/topic61043...stuck+park ... - .- -.
Post #704858 19th Nov 2024 9:34pm
JLS
Norway
Yes. Can see the brake light shine too…. So the switch is ok, if it’s the same switch, and not a separte one for the box?
I understand its a costly part to change - yippiiii - just bought and changed the rear diff… That wasn’t cheap either Razz
… I’m starting to miss my D3…. Nearly faultless during 5 years ownership compared to the two month old (to me) L405…
I thought a ten year younger car should be a sweet experience Wink 2016 L405 SDV8
1965 MB 230 SL
Post #704859 19th Nov 2024 10:13pm
JLS
Norway
A quick update. The P lock issue is solved with some gaffa tape Whistle The solution nicked from YouTube… But, a tip for the other ones that have, or will have, the same problem: Follow the workshop manual to dismantle the gear selector unit, and not the one that you find on YouTube (the guy loosens the whole centre console, pulls it backwards and access the gear selector uniot from the front.). That´s a way to complicated way to do it! It´s supposed to be accessed/opened from the rear, leaving the console where it is!
Good luck! 2016 L405 SDV8
1965 MB 230 SL
Post #706376 8th Dec 2024 9:23am
Thanks for the update Thumbs Up ... - .- -.
Post #706379 8th Dec 2024 10:04am
fisha
Funnily enough mine did this the other day with my wife. She claimed not to have tried to turn the selector before it rose up fully but I don’t know Whistle
Anyways, I ended up repeatedly pressing the brake pedal on and off, and thumping the area just behind the selector a few times. The solenoid loosened and began working again. I’ll monitor it. V8 or else ...
Post #706571 10th Dec 2024 11:31pm
Vogue
Speaking from experience do not leave this - get the selector changed, an intermittent fault soon turns into a permanent one and it will definitely leave you stranded - most likely in a very inconvenient or dangerous place - doing a U turn, in a road for example or in a car park leaving you stranded in the middle of the road blocking it and causing a huge amount of stress to not only you but other drivers being also blocked in.
I’ve had 2 fail in 2 L405’s and the symptoms are always an intermittent fault, temporary lock out or a stiff selector turn especially after a long run. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #706577 11th Dec 2024 4:59am
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
seems like the sensible thing might be for us all to purchase a spare and have in the workshop for that very day!!
Post #706631 11th Dec 2024 5:43pm
fisha
£150 to £300 is a lot for a spare just to sit around. a roll of gaffer tape might be better value after all! V8 or else ...
Post #706642 11th Dec 2024 8:25pm
Kot
I have bought the gaffer tape, where do i put it Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #706655 12th Dec 2024 1:14am
Nasher
Vogue wrote:
Speaking from experience do not leave this .
Yep, Don't leave this, it will get worse and at the most inconvenient time.
When the rotary selector in my D4 decided to stop rotating I'd just reversed out of a parking bay in a car park and was stuck in reverse blocking the road, unable to go forward again or even select neutral to roll it out the way.
I turned the ignition off hoping it would sort itself out but it didn't. I wasn't going anywhere.
I had an embarrassing 15 mins whilst I stripped out the centre console and split the halves of the module to push the lock back with a costa stirring stick.
I was lucky the owner of the car I'd reversed up to and was blocking in didn't return in that time.
And I'm obviously lucky I have the tools in the car and am able to do the work.
The replacement I modified before fitment with the 'cable Tie mod' which enables me to pull the tail of a cable tie tucked up just under the console to pull the lock back if needed.
Post #706667 12th Dec 2024 10:09am
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
So now, as well as worrying about: blocked DPFs, regens, snapping crankshafts, stuck EGR valves and various turbo problems I have to worry about it sticking in gear. Oh well, more sleepless nights till I find out where to put the gaffer tape. 😕
Post #706683 12th Dec 2024 12:05pm
dont forget the hammer... Very Happy ... - .- -.
Post #706704 12th Dec 2024 4:22pm
Gremlin500
Ah! I get it.
The roll of gaffer tape is for the irate mouths of the blocked-in carpark users, to shut them up? Very Happy
Or, where on earth does it GO???? Whistle V6 Vogue - “Less is More” - less to go wrong!
Post #706708 12th Dec 2024 5:05pm
fisha
My wife claimed it happened again. I get the in car, and it works perfectly.
I'm saying nothing. Whistle
As for the gaffer tape trick ( where you use it to hold the lock pin in its retracted position ). I was thinking that over time the tape would stretch and fail, and that a better solution might be a paper clip bent to shape to hook around and hold it back all the time.
Quick question .... is the locking pin only to prevent gear selection when in the P position ?
Cause I tried it today creeping along in D and didn't need to have the brake pressed to knock it into N and back to D again. V8 or else ...
Post #706724 12th Dec 2024 9:01pm
