Home > Technical (L322) > L322 Td6 GM 5L40E Gearbox
hgbosch
South Africa
Hi All
I have a weird one today. During a Gearbox Rebuild, a new valve Body with "802" Code plate was fitted. Originally there was a "347" Plate Code Valve Body in the Car,l
Since the rebuild the gearbox is hunting in 4th Gear between 25 and 45 miles/hr. It feels as if the TC is locking and unlocking with a 500rpm fluctuation on the engine.
Has anyone had this before?
Would appreciate some input.
Greetings from Sunny South Africa
Post #706634 11th Dec 2024 6:31pm
RRPhil
According to this Sonnax document, the 802 plate code is correct for the L322. The 5L40-E that I tore down (https://xoutpost.com/bmw-sav-forums/x5-e53...rdown.html) had a 376 plate (also on Sonnax’s list for the L322). However, there’s no mention of a 347 plate.
Phil
Post #706653 12th Dec 2024 12:57am
hgbosch
South Africa
Hi Phil
thanks for replying. Yes I know the 802 plate is on the list for the RR Td6 with the BMW M57D30 engine.
The Issue I am having with that new valve body is, that it shifts up to 4th gear at about 45km/h and then goes in and out of TC lockup. Aside from being annoying, I fear that the TC lockup clutch is not going to take that well.
Kind regards
George
Post #706661 12th Dec 2024 8:40am
RRPhil
Do you have access to any diagnostic kit which can measure and record live data? I guess the first thing you need to establish is whether the TC LUC solenoid is being wrongly triggered by the transmission controller, or if the LUC engagement/disengagement is caused by a hydro-mechanical issue with the valve body assembly.
Phil
Post #706671 12th Dec 2024 10:40am
hgbosch
South Africa
Hi Phil
thank you very much for this most valuable tip. I have the GAP IID Tool unlocked for my Range and my wife's Disco4 V8.
I will get to that this afternoon with my Samsung S8 tablet and will respond with the findings.
Absolutely awesome, how this forum works!
Kind regards from a VERY sunny South Africa
George
Post #706672 12th Dec 2024 10:50am
hgbosch
South Africa
Hi Phil
thank you very much for your assistance. With your help I was able to isolate the fault. Was the Gearbox TCU. Had another one here and after fitting it, rig behaved again.
So all sorted.
Kind regards
George
Post #706763 13th Dec 2024 11:14am
