![]() | Home > Maintenance & Mods (L405) > Diesel fuel leak - driver side RR L405 |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 442 ![]() ![]() ![]() |
Possibly leaking from the bottom of the fuel filter and then running down the bulkhead and back. Worth a quick look at the filter to see if its wet. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
pec2960dk Member Since: 15 Dec 2024 Location: Copenhagen Posts: 5 ![]() ![]() ![]() |
Thank you for your help. Will look into that tomorrow ,🙏 |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1441 ![]() ![]() |
its not from the fuel burner heater is it? 2018 SE SDV8 4.4 Byron Blue |
Thank you. Could be. But I thought that is located passenger side ?
Mcdaddyjester Member Since: 08 Nov 2024 Location: Worcester Posts: 5 ![]() ![]() |
Hi
Thank you for your input.
I put the suspension in the highest setting and crawled under. It was kind of obviously after a few mins with a torch. Biggest issue was the number of joints. I reconnected three but others just popped off. I think I should have replaced the entire system as I think I probably had a blockage somewhere. Part ex'd the car in the end for a l405. |
Thanks 👍. I will give it a go.
Brave man ![]() |
