![]() | Home > Technical (L322) > The Motor Oil Geek |
Andra Member Since: 22 Sep 2015 Location: Scotland Posts: 83 ![]() ![]() |
https://www.youtube.com/@themotoroilgeek
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1393 ![]() ![]() |
- wait until you find out about what gear teeth do to the oil in the gearbox and you will be changing this every week ![]() |
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 192 ![]() ![]() ![]() |
Damn! I better start changing my gearbox and different oil every 3 to 5k also....
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 128 ![]() ![]() ![]() |
As the guy states at first: it's about data.
I assume one of the below statements is true,
There is only ONE way to find out what category the fresh oil of your choice falls in.
If you are doing very low anual mileage and also lots of short trips then a 2x yearly oil change is likley beneficial but not for the reasons mentioned. Oil temperature takes way longer to get up to to the level it will evapourate off water accumulation from cold start blowby gases than coolant temps and in winter this may not even happen. 2012 TDV8 Vogue (L322) |
I have owned the car 2 years and done circa 11000 miles in total. I will use it more in the next 12 months but doubt I will cover more than 6 to 7000 miles max. I avoid very short journeys and if I go on a short journey I usually take it for a dtive afterwards to get it up to temperature. 2012 4.4 TDV8 Vogue Santorini black ivory leather |
