![]() | Home > Technical (L322) > 2012 l322 suspension fault |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2745 ![]() ![]() |
Not answering your question, but if you can get the car up to normal height then pull the 20A main suspenison fuse from the rear fuse panel then it won't be able to lower.
joejoe300 Member Since: 22 Dec 2024 Location: Nottinghamshire Posts: 13 ![]() ![]() ![]() |
I have it says c1ao4-21 left front height sensor |
Paul H Member Since: 17 Oct 2023 Location: coventry Posts: 87 ![]() ![]() ![]() |
did you replace with the correct sensor, the 2012 have adaptive and use all 6 pins and the earlier ones only use 3 of the 6 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea! |
Yes I replaced it with 2 new ones and still get the same fault code |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 941 ![]() ![]() |
I seem to recall it’s possible to fit the height sensors upside down without it being obvious - may be worth double checking depending on who fitted them. Jonathan
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3329 ![]() ![]() ![]() |
As said it's easy to fit them the wrong way. Also the wiring is poorly protected ( typical of the whole car) so it may be this is the fault and not the actual sensor. 2012 TDV8 Vogue (L322) |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8795 ![]() ![]() ![]() |
As JayGee said the wiring is a weak point, IIRC they sell a part lead with a new plug and tails which will need fitting... |
Hi all just had a look at the voltage at the top of the dynamic strut tops on the front both read 0.88 volts
Right front voltage looks unusual but check the voltages at access height and off road height so you can confirm they are all changing and in the same direction. Does your diagnostic tool have a suspension calibration function like the GAP IID tool? 2012 TDV8 Vogue (L322) |
Hi I have done the calibration but the car wont go up on the suspension keep getting dynamic suspension fault on the display and left front level sensor fault on code reader |
will it go to access height? 2012 TDV8 Vogue (L322) |
It dont seem to want to go up at all |
Access height is down 2012 TDV8 Vogue (L322) |
Just checked my height sensor voltages and the front right also seems to have a low value compared to the rest so this may just be a quirk of the system as the actual heights are within 10mm of each other all round.
