![]() | Home > Technical (L322) > 4.4TDV8 leak from fuel filter .... AGAIN !! |
| Kiss My Carbon Footprint Member Since: 19 Dec 2020 Location: Milton Keynes Posts: 147
Chaps,
| Crusty21 Member Since: 29 Mar 2022 Location: Cheshire Posts: 48
I have now finally .... fingers crossed .... resolved the problem |
Well done matey. And thank you.
Good luck with it Warwick ..... I'm confident you will sort it |
| Joff1961 Member Since: 24 Dec 2023 Location: Wroughton Posts: 18
Have been having same issue on my 2012 Winchester, just had the £30 part in the post, also have a Land Rover part LR072685s which is £149.99 from a well known off road parts company which if the £30 part works the other part will be going back. |
Although I did acquire a (Ford) fuel filter housing/assembly, I didn't get around to using this. With nothing visibly amiss with the existing kit, I felt disinclined to replace it except as a last resort.
The Ford filter housing is not a replacement for the JLR housing, nor is the filter that comes with it.
Yes, quite right. Having not looked at this for a while and with my focus having shifted to the fuel filter, I'd forgotten the detail.
| Benji1 Member Since: 11 Sep 2023 Location: Perth Posts: 44
From my experience your leak is coming from the sensor.
| All times are GMT |
