![]() | Home > Technical (L322) > TDV8 Not starting and brake pedal will not depress. |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 261 ![]() ![]() |
My TDV8 is on the CTEK in the garage most of the time. Ditto the BMW in fact. It gets plugged into the white tow socket via an adapter. Particularly handy at this time of year as I can fire up the remote heater without worrying about the battery. If you don’t have the tow electrics, you can still hook it up straight to the battery although you’ll obviously have to either wire in the socket or connect it via the clips.
Johnmann10 Member Since: 10 Jun 2024 Location: Rugby Posts: 16 ![]() ![]() |
Thanks for the advice.
https://www.britpart.com/parts/winching/ba...ors/da1409 2021 3.0 P400 Vogue
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 697 ![]() ![]() ![]() |
If you’re going in via the tow socket, make sure you get the right pin connector, 7 or 13.
Benji1 Member Since: 11 Sep 2023 Location: Perth Posts: 35 ![]() ![]() |
Simple fix for this.
Andra Member Since: 22 Sep 2015 Location: Scotland Posts: 83 ![]() ![]() |
Might want a 10 amp battery charger for the big battery . Ctek are ok I’ve been using them for more than a decade and still going .
Thanks all.
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 102 ![]() ![]() ![]() |
Tis the time of year that weak batteries throw their hand in!
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
The "Wiki" is your must go-to place on here |
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 128 ![]() ![]() ![]() |
As far as I know the not starting and the hard brake pedal are unrelated.
The brake pedal needs servo assistance to be able to comfortably press it down enough to engage the starter safety switch. It only takes 1 or 2 pedal actuations as a result of a no start to drain it. 2012 TDV8 Vogue (L322) |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 76 ![]() ![]() ![]() |
Just out of interest. If this is the case, how would you be able to start the car following maintenance which drains the vacuum system or on a vehicle that has been standing unused for a long period. |
Thanks all once again.
you just have to use more force to push down on the brake pedal than normal. 2012 TDV8 Vogue (L322) |
