![]() | Home > General (L405) > Engine failure £13,000 |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1731 ![]() ![]() ![]() |
Sorry Chris, but for the record, the latter comment is simply incorrect: JLR have consistently mounted vehicle DPF’s too far downstream of the exhaust manifold in several vehicles, including the L494 and L405 as well as the smaller siblings you mentioned. Dilution can be a problem in any diesel JLR product. However, I would say that the dilution algorithm can often overestimate dilution level. Based on testing oil samples in my own TDV6, dilution increases about 1% per 2500 miles mostly urban driving. I tend to change oil at this interval, since it coincides with 6months of driving for me. One caveat is that I monitor regens in almost an OCD way and rarely have an aborted regen. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 376 ![]() ![]() ![]() |
Remember reading that the cat problems wre worse where the engine was transversely mounted which forced the positioning further down the exhaust.
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1163 ![]() ![]() ![]() |
Feel the same if I was to change it would be the 4.4 BMW Engine or the supercharged V8. overfinch modified |
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 176 ![]() ![]() ![]() |
My tuppence worth (and has served me well) is if you own a diesel RR you must learn how to change the oil and filter yourself irrespective of dealer servicing (which should be done alongside your own oil changes for waranty support). I change my RR oil every 3 to 4k miles with quality oil and filter. It costs me circa £75 plus an hour of my time. The oil pump is a manual one from amazon costing £45 but there are plenty of manual and powered options.
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 668 ![]() ![]() ![]() |
Hi, I've had experience of this with a Mazda in the past, it's pretty much common to all DPF based diesels with the diesel injection regen process and since then I have always changed the oil every 5000 miles.
Has anyone wrapped the exhaust manifolds/pipe to maintain the temperature to aid the dpfs efficiency? We used to do it on rally cars to take temperature away from the engine bay so should help especially where the dpf is fitted further back on the exhaust. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 532 ![]() ![]() |
Good shout V8 Bob,
No not on Westfield forum although I have often considered building one! Used user name since I had a classic V8 Range Rover. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3257 ![]() ![]() ![]() |
We've had a Discovery Sport Hybrid courtesy car for almost a month now.
harisson Member Since: 24 Jan 2022 Location: Switzerland Posts: 11 ![]() ![]() |
.. in the beginning of the thread there was a misunderstanding about the technology (what is Ingenium?)
