![]() | Home > Maintenance & Mods (L405) > Oil Extractor Pumps with good length pipes - recommendatios |
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 177 ![]() ![]() ![]() |
I think they all have pipes that are too short for use on a Range Rover as the height up to the engine bay takes up a good portion of the pipe. Probably fine on a ‘normal’ car.
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 252 ![]() ![]() ![]() |
Hi Alex1976, were there any specific characteristics of the rubber piping that you bought to consider?
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1400 ![]() ![]() |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1776 ![]() ![]() ![]() |
Good point, this post.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1473 ![]() ![]() |
Read this thread too.........
@Rob99:
@Gremlin500
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 778 ![]() ![]() ![]() |
Definitely 8mm on the SDV8 too. Kev
Sun's out here so just checked the tube size and it is 8mm ID that I used. Previous post edited |
Thanks both for confirming, so it’s the same no matter v6 or V8 Fullfats.
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 676 ![]() ![]() ![]() |
Hi,
IRBails Member Since: 25 Jan 2016 Location: Shellharbour;NSW Posts: 14 ![]() ![]() |
I purchased a 12v Pump like this
TomekW Member Since: 01 Jun 2023 Location: Warsaw Posts: 10 ![]() ![]() ![]() |
I am using Seaflo 12v gear pump
I found PVC gets too soft with the hot oil and collapses almost flat, constricting the flow, whereas the nylon is much harder and resists collapse, assisting the flow.
