Home > Maintenance & Mods (L405) > Locking wheel nut key obsolete
Pablo398
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Hi all, I’ve lost my locking wheel nut key and just found out it is now obsolete. I’ve spent most of the day calling everyone I can think of an no one has them in stock although numerous websites state they are in stock. I’m after coda A according to my local landrover dealer lr043796. I don’t suppose anyone has any idea where I can get one or the easiest way to remove them. I’m happy to replace with not locking nuts once removed and if there is a kit to remove for reasonable money I’m happy to buy it. I have attached an image of the key I need. Thanks
Post #707871 30th Dec 2024 4:30pm
Think there was a set of nuts and a code A key in the for sale section……
https://www.fullfatrr.com/forum/topic72148.html
And they are FOC…..👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #707872 30th Dec 2024 4:32pm
Pablo398
Thanks I’ve sent a PM let’s hope he’s still got them. 👍
Post #707873 30th Dec 2024 4:42pm
Dumb question, but are you sure it's lost ?
Someone a while ago posted a similar question, but then found theirs in it's proper location in the spare wheel well on the left as you look in.
Another option is a universal locking nut remover then get 4 plain nuts to replace them. Locking wheel nuts only ever seem to cause problems for the legitimate owner. Any wheel thief who could get a FFRR off the ground would have no problem defeating a wheel nut......
Post #707876 30th Dec 2024 5:05pm
It’s a good point the proper place is hard to spot as it has a cover over it….. There is nothing that can't be fixed with a hammer😜😜
Post #707878 30th Dec 2024 5:07pm
Pablo398
Yes definitely lost took me an age to find the first time so will never forget its place. Thanks anyway.
Post #707879 30th Dec 2024 5:12pm
Glackowitz
United States
I just removed my locking lugnuts, bought the car and found it had no key. Used a 21mm 12point socket, just slightly fits over lugnut, tapped it on about 3/8 of an inch to make sure it doesn’t slip then used a breaker bar to take it off. Left it a little bit on the stud to work the socket off the lug then finished removing the nut by hand, put oem regular nuts back on.
Post #707907 31st Dec 2024 8:15am
