Home > Maintenance & Mods (L405) > L405 key fobs not operating today - Happy Christmas
garyRR
Do you have a battery smart charger? I'd put it in test mode on each battery and test the remaining CCA and also charge it to 100% and see what voltage it reads. Anything less than about 70% can cause issues. 2015 Range Rover Autobiography 4.4 SDV8
Post #707923 31st Dec 2024 12:06pm
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
I charged using a ctek that took the charge over 80% of capacity which didn't make any difference. After the 5 hour charge and a 45 mile drive 2 days later Halfords said it was around 70% on the CCA. The strange thing with the battery is low voltage, typically 12.1V to 12.3V.
Two days later after sitting in the driveway its at 12.2V and 42% so there might be a can bus wire short going on.
Post #707924 31st Dec 2024 12:14pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
What’s the voltage with the engine running ? Should be circa 14.4 is less than that probably an alternator issue 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #707926 31st Dec 2024 12:26pm
garyRR
Sounds like the battery and nothing more complex than that, to me. Remember cold weather can quickly kill weak batteries.
I'd be looking for a 100% charged voltage to be at least 12.5V and a CCA test run showing at least 700A. 2015 Range Rover Autobiography 4.4 SDV8
Post #707927 31st Dec 2024 12:27pm
baz000000
The car charging voltage on a running engine is 14.8V so there is nothing wrong with the alternator.
Post #707936 31st Dec 2024 4:23pm
baz000000
Update on this:
The car is booked into an independent garage on 13th January for the electrical issues and a few mechanical fixes so I had a few days spare to play with things. I bought a battery tester and put the battery on charge for 48hrs. The battery went from 12.1V to 12.4V and the CCA from 50% to 77%. So, the battery isn't great but not totally lost.
All the electrical issues of smart key not recognised, no stop/start, auto lights no available have all been restored following the 48hr battery charge. With the battery only attaining 12.4V it probably has some sulphation so when I get a few days free I'll do a couple of sulphation charging cycles on the battery to see if it can raise the standing voltage. If it doesn't then I'll need to replace the battery ahead of next Winter. Halfords warranty doesn't cover poor/reduced battery performance so there is no comeback there. They regard anything that holds above 10V is good to go.
Post #708625 8th Jan 2025 12:33pm
enzo19352
Hi, did you get this issue sorted sorry to ask ? I just brought a range rover a few days ago with this issue Smile
Post #713705 10th Mar 2025 2:09pm
baz000000
It got kind of sorted. I left the battery on charge for 72hrs and that raised the capacity to over 70% and the voltage to 12.7V. Then the Gremlins were beaten and have yet to return.
Post #713706 10th Mar 2025 2:11pm
enzo19352
Hi thank you for your reply. by any chance did this stop your phone connecting and the audio tab being blurred out?
Post #713707 10th Mar 2025 2:25pm
baz000000
No, I never had that issue. I would have noticed if it had as I Bluetooth the phone for music.
Post #713708 10th Mar 2025 2:32pm
