![]() | Home > Maintenance & Mods (L322) > The Best oil for the 4.4 V8 M62 engine? |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 ![]() ![]() ![]() |
Hi all, its that time again! , need to get tankers worth of new engine oil and am looking for everyones advise on the best for this engine?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35765 ![]() ![]() |
i cant comment of the make of oil but you do need some very low temperature stuff to cope with your climate up there... |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
I put Mobil 1 in mine. As far as I'm concerned the best oil you can buy off the shelf. Costco sell it for £24 for 4L. |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
i use commo from my car parts supplier ....they used to/still supply formula 1 cars so good stuff |
DeltaC Member Since: 23 Mar 2010 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
Rob,
FUCHS Titan SuperSyn is the BMW OEM Preference. It's a bit expensive these days, I used to pick it up from G&S for £16 for 5L. |
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 ![]() ![]() |
I use Castrol Magnatec. |
Trist78 Member Since: 07 May 2011 Location: Worcester Posts: 78 ![]() ![]() |
Just put Morris Lubricant 5/40 multivis fully syn on mine !!
I heard Mobil 1 is a bit on thi side for vanos units???
Yup - Magnatec is fully synthetic 5W 30. |
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 ![]() ![]() |
I'm about to change the oil and wondered with the bmw vanos would 5w 30 or 5w 40 fully synthetic be better? |
Still no answer to the above then. I am trying to find out the best/correct BMW M62 Oil choice. It seems 10w40 is correct but 5w30 is Ok. Which brand is BMW or Land Rover recommended for this engine? |
there's a recommended lubricant info in the wiki, any help? ... - .- -.
