Home > Maintenance & Mods (L322) > Rear subframe removal
Superspoons
Excellent work there - looks brilliant, hats off to you Thumbs Up Gavin
https://www.youtube.com/@ChallengingClassics
Post #707174 18th Dec 2024 10:31am
Baltic Blue
That’s what I call detailing, brilliant job.
Have you got any photos of the body underside before refitting ?
Post #707176 18th Dec 2024 11:26am
jammez
Thanks for all the comments folks!
I'll take a few pics of the underside before I refit it. Not much to show as it's mostly covered in dinitrol now!
I'd previously repaired the rear sills so there wasn't any major rust underneath apart from the holes in the spare wheel well.
I've just removed the plastic covers that go over the fuel tank, I was surprised how much crap was in them. I think I've removed a couple of KG of mud that's collected in them. There's a couple of metal panels that form the sides of these covers so I've cleaned those up and repainted.
Next years job will be the front end as it's looks crappy in comparison now! (or I could finally make a start on the these 2 and get one of them ready to sell!)
Post #707181 18th Dec 2024 12:43pm
jammez
Hi Folks
Quick pic of the underside before we did a test fit of everything.
The subframe went in with no problems, couple of brake line to make up and then I'll be able to do the final fit in between Christmas & New Year.
The final cost of parts and paint came to £1600! Not a cheap exercise but hopefully it means the (back of the) car is good for another 20 years! 2008 L322 Supercharged
1994 Soft dash Vogue SE
1993 Hard dash Vogue SE
Post #707559 24th Dec 2024 10:36am
dhallworth
Doing the rear frame is definitely an expensive project but it's one that's 100% worthwhile doing if you've got intentions to keep the car long term.
I think I'm going to drop the rear end off my 2012 next year at some point so I can do the same. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #707565 24th Dec 2024 11:57am
jammez
Hi Folks
Happy new year! Last week I managed to get some time to re-fit the subframe and not everything went to plan!
The connector to the rear right ride height sensor got squished so I had to replace the connector. Since doing that I can't get that sensor to work so I need to investigate further. Can't seem to get power to it, the reader is showing no volts and a quick check with a volt meter isn't showing any volts on the wires. Further investigation required on that one.
The parking brake, which didn't work before, still isn't working properly. Previously it didn't work at all but I had no dash warnings. It now works when you're moving slowly, it'll pull on the rear brakes but doesn't do anything when parked up stationary. It also now shows a fault message on the dash so I'm one step forward on that one & one back!
Ran out of time over the holidays so will need to re-visit it over the next couple of weekends 2008 L322 Supercharged
Post #708257 4th Jan 2025 2:49pm
Weegie
When you “squished” the sensor is it possible that you got a short blowing a fuse? Unlikely I know as I don’t expect you would have power going to it but just a thought. John
GAP iiD BT-Sold
Post #708260 4th Jan 2025 3:19pm
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
Going to be doing this on my 2012 4.4. I've previously done an Aston Martin V8 Vantage subframe which went very well, so got some confidence to do my Fatty, especially after these write ups. Thank you for
everyone who's written up their experiences.
I have a used 2012 subframe and ancillaries on the way, so will get it all stripped down and then off to Hunter Steel in North Wales. They did my last subframe project. Rather than just blast and powder coat it, they applied a multi-stage finish which is guaranteed for 20 years in a marine environment. Should well outlast the car.
I'll document progress as I go along. Ideally I'll do the swap over myself on the drive, but as I use the car as a daily driver, I'll need to investigate the steps fully. Separating drive shafts etc might cause some headaches and don't want to be stranded.
If anyone wants to speak to Hunter Steel about what they can do speak to Harry on 01244 541177 - really friendly and super helpful.
Post #712988 28th Feb 2025 10:47am
jammez
Hi Folks
Believe it or not I've be exceptionally busy I haven't actually managed to get the RR going since refurbing the rear subframe in December. I've finally got a bit of time & also a newly purchased GAP ID tool to sort out the suspension. I mentioned I squished one of the plugs to the rear height sensor so had to replace that plug.
It's currently flat on it's bump stops with the EAS doing nothing. GAP ID is showing supply voltage to all sensors but 0v in the Voltage reading. Couple of questions. What's the difference between those 2 voltage readings? Supply Voltage is self explanatory but what's the other one referring to? Any ideas why that would be reading 0v?
Both sensors were replaced as part of the refurb so unlikely they're both faulty. Any thoughts folks? Cheers James 2008 L322 Supercharged
Post #717613 8th May 2025 3:40pm
