![]() | Home > Technical (L405) > Oxygen sensor replacement |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1531 ![]() ![]() |
Fuel delivery, air flow sensors and exhaust sensors are probably one of the areas that benefit from genuine parts to be honest.
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 392 ![]() ![]() |
Thanks Fish, much appreciated! |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1422 ![]() ![]() |
Are not most OEM parts made in China ? Several post on here and other marques with owners and dealers waiting for that slow boat! 2018 SE SDV8 4.4 Byron Blue |
Re-reading the op, regarding aftermarket part brands, as long as you could be satisfied that a part is genuine Bosch, then it’s is probably one brand which I would think is likely to be OK as an alternative. I was speaking more about the brands which you’ve not likely heard of . V8 or else ... |
Hi Fish, I installed the new OEM oxygen sensor bank 2 sensor 3 which was very easy but was wondering how many sensors the 2016 l405 has? I have read 4 and 6?? |
There are normally sensors each side of the catalysts to measure the cat is doing its job. So iirc each side will have a cat downstream of the headers.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1832 ![]() ![]() ![]() |
I found this in the WM above, for the V8 petrol, I would think its the same for all engines?
