![]() | Home > Technical (L322) > Bypass |
A.Pires Member Since: 02 Dec 2016 Location: Seixal Posts: 158 ![]() ![]() ![]() |
Did Someone done a bypass to the starter motor with a start button on the td6? |
Can anyone answer my question about connections? |
Mr K, I know very well how to make a direct connection from a switch to the starter motor. What I don't know about this car is whether this will affect any electronics or whether errors will appear on the dashboard. That's my question but nothing |
KF Member Since: 19 Jul 2022 Location: Kerava Posts: 46 ![]() ![]() ![]() |
How would it know that there is an extra live cable? Starters usually have 2 cables, a thick one for juice and a thin one from ignition switch. Now you are adding another live from an extra switch for some reason, I did that for my Pajero due to irregular problems with transmission neutral switch, which was preventing the car to start from a key.
Mr. KF
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 88 ![]() ![]() ![]() |
Uhm, you do know that the TD6 IDE & EWS modules are designed to prevent theft and need to talk to each other to allow the starter to crank ?
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 152 ![]() ![]() ![]() |
Surely that can’t be the case with a rolling code being stored on the key and that needing to be in sync? If it was, you wouldn’t be able to use a second key! |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 77 ![]() ![]() ![]() |
By your description of starter not engaging . Sounds as though teeth could be damaged on the flywheel ring gear, or starter motor pinion. |
Rolling codes are maintained by the EWS for 4 of the key IDs that may be active at any one time (from the 10 key IDs assigned to the EWS by the manufacturer). Data is exchanged by RFID and the keys get a new code calculated from a builtin algorithm ~10s after each successful start. IDE & EWS advance to the next code in a table that was passed from the EWS to the IDE at its first bootup.
