Home > Maintenance & Mods (L405) > Rear Anti Roll Bar Links - MY17 SDV8
JamboM3
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Indus Silver
Hi,
Need to swap mine out again and I cannot find anywhere than confirm the parts numbers required as there seem to be a few options.
Mine is a SWB March 2017 car (with facelift screen etc).
Advanced factors mentions bright/dark finish as a difference but I had these swapped out with some rubbish quality ones so do not have the originals to compare them to.
Anyone got an EPC tell me the correct ones?
Post #707811 29th Dec 2024 3:04pm
This one works Thumbs Up
https://parts.jaguarlandroverclassic.com/p...and-rover/
They seem to all come back to the same part number, have a click through, ones with ACE seem to have the same as the non ace cars. But are handed L and R. There is nothing that can't be fixed with a hammer😜😜
Post #707824 29th Dec 2024 6:18pm
Bagus
United Kingdom 2016 Range Rover Autobiography 5.0 SC V8 Loire Blue
Part numbers in this link https://www.fullfatrr.com/forum/post671902.html 2016 5.0 Loire Blue
2002 4.4 v8 Adriatic Blue
Post #707892 30th Dec 2024 10:15pm
JamboM3
Thanks both, I was able to verify the numbers on JLR classic. Haven't used that site in a while and finding L405 stuff on there wasn't straightforward as there used to be no navigation but you could locate via PN.
Also I wanted to verify by VIN range the correct numbers, so I was aware of the old thread but had issues with the stuff fitted so wanted to be 110% sure of the fitment.
If anyone is reading this in future the correct numbers are (for VIN Range: TO VINFA999999 FROM VINEA000001)
LH - LR166064
RH - LR048093
Post #708215 3rd Jan 2025 9:39pm
CJames525
United States 2017 Range Rover 5.0 SC V8 Santorini Black
With the dynamic response system, how hard is it to change out the rear/any DIY’s or write ups? Parts are coming in Monday to do mine, as I have a horrific creak like an old mattress when driving with the slightest bit of articulation. Hoping it is the bushings, but being I have a 2017 figured they were due anyway and a good place to start.
Thank you.
Post #708832 11th Jan 2025 3:26am
Fifth Horseman
Rear bushes are easy, fronts are a PITA as the support bracket has to come off and the bolts for these may strip the threads on refitting.
https://www.fullfatrr.com/forum/topic71328.html
https://www.fullfatrr.com/forum/topic67721.html
Post #708833 11th Jan 2025 9:40am
JamboM3
My indie is doing mine, one thing I do know from the procedure is to clean up the surface for the D bushes very well as this can cause creaking (your creak is likely from excessive movement tho!)
Post #708842 11th Jan 2025 12:15pm
