![]() | Home > Finance, Insurance & Warranties > Warranty Wise Claims on My Range Rover L405 4.4 |
Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 251 ![]() ![]() ![]() |
As a Range Rover L405 owner, I wanted to share my frustrating ongoing battle with Warranty Wise regarding two major issues: the oil cooler and the auxiliary water pump/thermostat/heater valve assembly. If you’re dealing with warranty claims or considering buying one, here’s a breakdown of what’s happened so far and why I’m fighting back.
Thanks for encouragement.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 789 ![]() ![]() |
As a general point I’ve learned that whenever dealing with Warranties, Insurance,Police etc. NEVER volunteer any information or answer any question that hasn’t been asked. Remember that anything you say could be used against you. |
totally agree --
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 276 ![]() ![]() ![]() |
Which plan do you have with Warranty Wise? I have the 06/60 cover and they covered everything for my Oil cooler replacement except for engine oil.
I have 08/80 plan. Could u possibly pm me anything which shows that they covered gaskets and seals etc?
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 312 ![]() ![]() |
To what gasket do you refer? When replacing the oil cooler it comes with a new seal. 2012 Vogue TDV8 in Aintree green over sand |
My understanding is that a new gasket should be fitted with an oiler cooler. They cost about £20. The extra labour to fit is 4 hours. I think they’re trying to claim that gaskets aren’t cover but I think this is an mis interpretation. A blown gasket prob isn’t covered but where the gasket has to be replaced when a covered item is replaced it should be. --
I think some clarification is in order. The oil cooler has only one seal to renew and it comes with the new cooler. It is automatically changed as part of the job. The lower seal in this picture.
Thanks so much for the schematic. Is that for the 4.4 l405 engine?
I am none the wiser. The mention of the DPF is confusing.
Thanks Toby,
on this basis, the garage could be right. Perhaps it is sensible to replace the old cooler gasket simultaneously? I do have a visible oil leak from the oil cooler area. I'm not sure about any contamination. The engine isn't overheating. Failure of the gasket itself wouldn't be covered but as a gasket related to a covered part (oil cooler) and given it's called the oil cooler gasket - would suggest it is related to the old cooler? and therefore should be. the DPF mentioned might just be that if the vehicle has a DPF because of it's position it takes longe to fit the gasket?? But what do I know... Andrew -- On my third Full Fat RR Last edited by Ukandrewf on 13th Jan 2025 10:56am. Edited 1 time in total |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 366 ![]() ![]() |
Garage inflating prices to make it worth dealing with the warranty company in my opinion.
I didn't know about the wipers and scuttle (I was using my 332 as experience as I have done it) so yes, the 405 will be a bit longer than two hours then, but still not six.
