![]() | Home > Technical (L322) > Fault codes dissappear when engine warm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3380 ![]() ![]() ![]() |
It’s entirely possible a sensor could come back into life / spec when warmed up. 2012 TDV8 Vogue (L322) |
Apps Member Since: 24 Dec 2024 Location: Leeds Posts: 34 ![]() ![]() ![]() |
Yes it's just annoying. I think I will replace the map sensors and see if that helps the issue out |
Is yours a 4.4 or 3.6? If the former there is only one MAP sensor on the top of the 'donut' shaped intake under the engine cover. Worth removing in and cleaning out the soot which rapidly builds up and checking the wiring / connector for electical continuity. 2012 TDV8 Vogue (L322) |
Mine a 2010 3.6. So I think there is 2 on the top of the engine |
Even easier then - swop them around and see if the fault follows to bank A 2012 TDV8 Vogue (L322) |
Yes good idea. When I get home and try and let you know. What ramge rover do you have? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
Hover your cursor over the little picture of a Rangie under the persons name in the left side box. It will show you what car they have, if they have filled in their profile... Pete
