Home > Maintenance & Mods (L322) > L322 5.0 SC - Timing Chain, Coupler or something else?
HMAK2121
Bahrain 2011 Range Rover Supercharged 5.0 SC V8 Bournville
Hi all, I recently purchased a beautiful 2011 L322 Supercharged. Single Owner, Dealer maintained, in very good shape. The previous owner has not had the timing chains serviced and I am hearing some sort of rattle from the engine bay and cannot pinpoint whether it is the supercharger coupler, timing, or something else. Hoping for some help or advice as members of the forum would have much more experience than me with these cars.
There is a rattle on acceleration, and when cruising at low speeds there is an intermittent chirping almost as though there's birds in the engine bay. The car puts power down smoothly and if I give it the beans it takes off. There is a leak in the valve cover gaskets and the speedometer shows that the oil level is at the halfway mark. When I turn off the car after a 20+ minute drive, there is a short rattle that occurs as the engine shuts off (Lasts for 1 second as I press the start/stop button to turn off the engine).
A local indy diagnosed it as a timing chain issue just by hearing it for a few seconds without even properly checking. I have checked part of the timing chain through the oil cap, the chain is as tough as concrete absolutely no play or slack whatsoever. Dealer informed me that this is one of the few VINs that was not affected by the recall, oil was changed roughly every 10-13k KMs (6-8k Miles). Coupler was never replaced.
Could this be from the Supercharger Coupler or is it a Timing-related issue? Could it even be something else like the leaking valve covers and the engine oil level being at the halfway mark? Car is mint other than that and I am finding it hard to believe that the (tightly tensioned) chains and kit are worn as the car has never been abused, and I am not hearing any noises like rocks bouncing in the engine.
Highly appreciative of any insight or advice regarding this issue and I have attached a link to a short clip of the engine noise when idle.
UPDATE: Timing chains replaced, problem persists. Engine pinging on acceleration, hesitating and bouncing RPM, smoke from exhaust. Mechanics informed me Vacuum Pump must be replaced. Can a bad vacuum pump cause engine pinging and hesitation? New video clip attached.
https://youtube.com/shorts/Pb_nqu0UFQ4
https://youtube.com/shorts/YF5j2e4LeN4
Post #709472 17th Jan 2025 6:35pm
Jofo
Canada 2010 Range Rover Supercharged 5.0 SC V8 Santorini Black
That is the loose timing chains based on the sound, sounds like a farm tractor/diesel truck. The age of the engine also is one of those engines that if it hasn't been done, then you should, personally I would not risk the possible chance of slippage.
I have seen these bad guides and tensioners on 2013 engines.
Post #709477 17th Jan 2025 6:48pm
HMAK2121
Yes Jofo, engine sounds really loud like a tractor. Car is driven 156k KMs (97k Miles). I know the diesel-like noise is usually indicative of bad chains/guides but could it not be caused by anything else? Just want to make sure I am not getting scammed or ripped off by mechanics.
Post #709478 17th Jan 2025 6:54pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Evening
I would say that definitely sounds like timing chains, I would drive gentle and get sorted asap.
Post #709484 17th Jan 2025 7:04pm
Yep, sounds like the chain has jumped one cog, any more and it could grenade the engine.... Shocked Pete
Post #709486 17th Jan 2025 7:07pm
HMAK2121
Thanks for the replies, will get chains sorted and update this thread within the next few days on whether my issue was solved or not. Hoping it is just the chain kit and nothing else Sad
Post #709491 17th Jan 2025 7:16pm
DrF
Good luck, you wont believe the difference in noise when done.
Post #709492 17th Jan 2025 7:52pm
HMAK2121
Thank you, the support is much appreciated! '11 L322 5.0 Supercharged - Bournville
'09 L320 4.2 Supercharged - Cairns Blue
'09 L320 4.2 Supercharged - Zermatt Silver
'05 L322 4.4 HSE - Alveston Red
Post #709499 17th Jan 2025 8:40pm
Other things to do while it is stripped down include hoses in under and around the supercharger. you can get the supercharger overhauled and change the injectors. Do a search, loads about it on here.... Thumbs Up Pete
Post #709523 18th Jan 2025 11:16am
HMAK2121
UPDATE: Dropped the car off to our local JLR specialist to get chains+ other items done while they are at it. Will post results and a video clip of the engine noise after the job. '11 L322 5.0 Supercharged - Bournville
Post #709691 19th Jan 2025 9:26pm
AlexTVR
Video clip sounds similar to mine. They are noisy engines, fuel injectors etc. The noise when you shut off car sounds supercharger related from what I’ve read.
FYI the timing issue is related to the guides, which I believe LR updated the parts around 2014.
Mine had a new engine under LR warranty at 96k miles, so for peace of mind it’s a job that will need doing sooner rather than later. Keep us updated. 2010 Supercharged
Post #709816 21st Jan 2025 6:18pm
HMAK2121
UPDATE: Got the car back, engine is quieter but the tapping/ticking noise has not gone away. Smoke from exhausts as well. Tapping noise is much more obvious since the engine is quieter and I have no idea why it still persists. Engine feels a lot smoother and after a road trip to another country I can say that there was definitely an issue with Timing Chains before the repair, just have no clue what this sound could be as the mechanics didn't point it out or raise it as a point of concern.
Video clip attached for reference:
https://youtube.com/shorts/n_awDNarCgQ '11 L322 5.0 Supercharged - Bournville
Post #710221 26th Jan 2025 1:17pm
TorontoDee
Canada 2012 Range Rover Westminster 5.0 SC V8 Santorini Black
Mine's always made that exact sound too. 2012 Supercharged L322
Post #710290 27th Jan 2025 3:08am
HMAK2121
@TorontoDee Do you think maybe my mechanics have not done the timing job right? Does the car have anything wrong with it or would you say it's normal? '11 L322 5.0 Supercharged - Bournville
Post #710355 27th Jan 2025 7:09pm
TorontoDee
I think you're good. I also had my timing guides done, and that specific mechanical 'hopping' or 'ticking' sound has always been there. And I sympathize with you, I've wondered what it is, and asked, and proposed ideas related to the fan clutch etc, but nothing came of it (yet - the sleuthing continues). Such an odd feature...
I would love to know though Smile 2012 Supercharged L322
Post #710359 27th Jan 2025 7:39pm
